Old 12-18-2012, 07:34 PM   #26
LEX
LEX's Avatar
Re: Small block starter tip of the week.....
Hey, guys. I'm in the process of swapping my starter with the O'Reilly one mentioned and noticed the broken gear in the old one. What do you think caused this? I don't want the new one to break. It's a PITA since I had to drop the header. I recently swapped the factory harness for a Painless. For a while it was fine until CLANK coming from the starter when I tried to crank it one day. Pics...
LEX is offline   Reply With Quote
Old 12-18-2012, 09:06 PM   #27
BarryB
BarryB's Avatar
I would double check your flex plate. no gouges or anything loose. If all checks ok, make sure you have that new starter shimmed properly, shouldn't be an issue.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-18-2012, 11:35 PM   #28
LEX
LEX's Avatar
Hey, Barry. I was thinking of shims, but never thought of taking a closer look at the flex plate. Thanks for the tip.
Old 12-19-2012, 07:33 AM   #29
c10srule
c10srule's Avatar
we just put one of those staters on my boys malibu, works great he loves it, spins over a whole lot faster than the high torque he had on it, thanks for the info,
c10srule is offline   Reply With Quote
Old 12-19-2012, 08:12 AM   #30
MARKDTN
Are you using the brace at the other end? The high-torque big starters are more sensitive to breaking teeth or the nose if you don't use the support brace. They are often missing.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-19-2012, 09:15 AM   #31
LEX
LEX's Avatar
There was no support brace and didn't know there was such a thing. Can I pick one up at any auto parts store?
*edit* I Googled it and will pick one up online somewhere to be safe. Thanks
[Posted via Mobile Device[/i]
Old 01-19-2013, 11:45 AM   #32
HotRod C/10
HotRod C/10's Avatar
is this the same starter $34.99? what is the "X" for at the end verses the non "X"
They also list a 03-0367m for $46.99.......
http://www.oreillyauto.com/site/c/se...yword=03-0367x
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 01-19-2013, 05:48 PM   #33
Andy4639
Old member
Andy4639's Avatar
Wink Re: Small block starter tip of the week.....
Not sure what that X means but it could be the differance between the staggered bolt holes and the straight across bolt holes maybe. I would think they could show you though.
This is mine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-19-2013, 07:11 PM   #34
gangforward
Hootis is as Hootis does...
gangforward's Avatar
I just installed one from Toshiba - thanks to a tip from the folks at Gearhead Performance in Clearwater. I was prepared to purchase the Revmaster - this was less than half as much.
I've got long tube headers - got really tired having to sit for hours waiting for the heatsoak to clear. Also installed new wiring and a dedicated selinoid. Works great.
As far as the whine - at the local 711 a fellow walking by when I blipped the starter said - Damm, that sounded like a race car starter....
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires
1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires
1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires
gangforward is offline   Reply With Quote
Old 01-19-2013, 07:27 PM   #35
BCOWANWHEELS
The fella with the broken starter teeth. I guarantee you that you need a flex plate now. You better pull the cover and rotate the flex plate 100% and inspect it at the least. Aalso check the mounting bolts/nuts for torque converter and flex to converter. Something caused this to happen. AND WHY ARE YOU FELLAS POSTING ALL THIS STUFF THAT IS NOT RELATED TO MY ORIGINAL POST ?
Jmo
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 01-20-2013, 12:19 PM   #36
elf w/capital T
Good post cause i was trying to figure out which one to get since i did buy a mini starter and the mount holes were different. Thanks!!
elf w/capital T is offline   Reply With Quote
Old 07-08-2014, 09:42 AM   #37
epon
epon's Avatar
Im looking for a high torque starter for the 305 and wondering if these suggested units will bolt right up. I contated the ebay seller mentioned above and 305's arent showing in his application charts but thinks it will fit with no gaurantees. Hoping someone has crossed this bridge and has wise words.
'82 C-10 SWB / C'd, Z'd, Body'd and Bagged / Shaved firewall, wiper cowl, drip rails, stake holes and tailgate/ 20" & 22" Milanni Voodoo
'81 C-10 SWB Parts Truck
IRC - http://webchat.snoonet.org/#baggedtrucks
epon is offline   Reply With Quote
Old 09-04-2016, 03:47 PM   #38
rustytruck50
rustytruck50's Avatar
Works great!!!! Thank you for the tip!!!!
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 07-24-2018, 07:35 PM   #39
WorkinLonghorn
WorkinLonghorn's Avatar
So BCOWANWHEELS, how is that starter holding up. It's time for me to get my starter replaced so I called O'Reilly and they have reman 03-0367 for $53 (special order). -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 07-24-2018, 07:57 PM   #40
Steeveedee
Who Changed This?
Steeveedee's Avatar
This would appear to be the tip of the decade! Something I have looming in my future is a flex plate replacement, as the gear reduction starter I bought many years ago appears to only engage about 1/4 of the way, and those flex plate teeth are looking mighty worn. I believe that it is the original flex plate. Didn't make it to 1/4 Million miles; I am quite disappointed. The engine needs rebuilding or replacing; I'm hoping that the flex plate holds out until I can do the work, if my hands get well enough...and I can find a place to do it. The only thing available to me here is the street. I've done some serious work in that street- we put a rebuilt /6 in my son's Dart, and when that went TU, we swapped the entire K-member and a V-8 into it, there in the street. I've also had the engine in my '68 Skylark in and out, there in the street.
I remember that back in the '60s we could get a shop to rewind a starter so that it could crank over an engine with 13:1 compression for the race cars. I don't know how those worked hot, however. My little gear reduction starter still cranks hard (it hits, but the engine just turns over slowly) when it's hot. Even after all the extra ground wires and running the battery ground cable all the way to the starter. I don't care if my truck sounds like it's grinding MOPAR brand coffee, as long as it starts under all conditions.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 07-24-2018, 08:19 PM   #41
bill3rail
bill3rail's Avatar
The decade...Almost, the thread started about 8 years ago!
Unfortunate for me, these are not available for the inline 6 with a three bolt starter.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-24-2018, 08:52 PM   #42
Steeveedee
Who Changed This?
Steeveedee's Avatar
But those have a hand crank, so life is good, right?
On a serious note, does the 6 cylinder have a hot start problem?
~Steven
Simi Valley, CA
Old 07-25-2018, 09:12 AM   #43
Domingo
What about the guys running the smaller flexplate 153 tooth
Domingo is offline   Reply With Quote
Old 07-25-2018, 12:07 PM   #44
Benjamin
Benjamin's Avatar
subscribed
1972 K10, 350/SM465/NP205, 4 inch lift, 35x12.50s on 15x10 wheels
1976 K20 crew cab, 350/Ranger/SM465/NP205
Benjamin is offline   Reply With Quote
Old 07-25-2018, 03:00 PM   #45
bill3rail
bill3rail's Avatar
My crank lever is broken so I installed the "Electrisicle Startering Dohickey"!
No starting issues, just looking for modifications that will help the truck.
Old 04-22-2019, 04:04 PM   #46
BCOWANWHEELS
went to buy aa second one, now there 82.00 bucks exch.
Old 04-23-2019, 06:13 AM   #47
Do you still have the vehicle with the starter you started this thread about? How has the starter been holding up?
Old 04-23-2019, 11:39 AM   #48
BCOWANWHEELS
yes, perfect now I,am building a 350/350hp engine and need another
Old 04-23-2019, 02:09 PM   #49
KQQL IT
At the body shop.
KQQL IT's Avatar
I have 3 of them.
2 - 454 trucks and 1 400 SbC
The 68 454 and the 73 400 both have headers. Never hot start blues. Would even spin the 400 with 36° initial timing.
https://www.amazon.com/ACDelco-337-1.../dp/B007QBT0WA
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 04-23-2019, 02:16 PM   #50
KQQL IT
At the body shop.
KQQL IT's Avatar
.... duplicate
Thread Tools
Display Modes
