Old 11-29-2012, 09:21 PM   #1
BCOWANWHEELS
Small block starter tip of the week.....
Guys i thought i,d share a fyi on small block chevy starters. If you want your old chevy truck to crank over like a race horse even on the hottest days and even with the heat off headers dont fool with stock 67-72 chevy truck starters. Get a starter off a 69-70 chevy corvette with a lt-1 small block there hi-torque starters. These are hi-compression engines. I have a 383 sbc with 10-1 compression and this oriellys life time guarantee starter #03-0367 really spins it over and its only $44.64. Plus you wont have that dreaded gear reduction whine. Hope this hhelps somebody out.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-29-2012, 09:29 PM   #2
Re: Small block starter tip of the week.....
Good info. We don't have O'Reilly's around here,though. But,using the 69/70 LT-1 Vette starter makes sense.
Old 11-29-2012, 09:33 PM   #3
LEX
LEX's Avatar
I need a starter and will look into this. Thanks.
LEX is offline   Reply With Quote
Old 11-29-2012, 11:13 PM   #4
BCOWANWHEELS
Advance auto,autozone and the rest have this starter too. It also makes it easy on your battery so it will last longer.
Old 11-30-2012, 06:31 AM   #5
JimKshortstep4x4
Good to know!
Is a core in needed?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-30-2012, 06:48 AM   #6
MalibuVLX
Good info. I have a 69 Corvette w/ 11:1 compression and I did not know they had higher output. I do however, use a mini high torque starter on my rockcrawler. I purchased it of Fleabay for about $60 w/ the shipping. I think it is the same one that GM puts out on the early 90's Camaros and Vettes. Sounds like a mad bee when it turns over, but much smaller, lighter and cranks like a bi$#&. No issues w/ heat sink either.
Here is the link. I am not selling these myself, but have installed one on my father's 83 square body w/ a 383 as well and he is thrilled w/ the results. Hope it helps.
http://www.ebay.com/itm/NEW-CHEVY-SB...item2319b2c215
MalibuVLX is offline   Reply With Quote
Old 11-30-2012, 07:16 AM   #7
jondancer
Good to know, need a new starter for those hot summer days
jondancer is offline   Reply With Quote
Old 11-30-2012, 07:55 AM   #8
hugger6933
I'm sure everyone knows about the starters off the vortec 350 motors from the 96-98 model years from the c-k trucks, they are great starters. But they do whine like one poster stated he wanted to stay away from. Jim
hugger6933 is offline   Reply With Quote
Old 11-30-2012, 02:00 PM   #9
specialtyretail
So,, what else you got???
specialtyretail's Avatar
These starters are the way to go. They spin the engine so fast, you don't even notice the whine. We run them on all our small and big blocks.
specialtyretail is offline   Reply With Quote
Old 11-30-2012, 02:42 PM   #10
BCOWANWHEELS
all the gear reduction starters dont compare to the quality of a good old gm starter. just like a new chevy trucks quality dont compare to 67-72 chevys IMO. THAT GEAR REDUCTION WHINE JUST SOUNDS TERRIBLE IN A OLD VEHICLE IMO
Old 11-30-2012, 03:22 PM   #11
leddzepp
Moderator
leddzepp's Avatar
I can deal with a gear reduction whine that lasts a fraction of a second at start up
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-30-2012, 03:48 PM   #12
c10srule
c10srule's Avatar
i have mini starters on both our trucks, couldnt imagine if it took a couple seconds to start, they both fire right up and i dont notice any whining noises, but the boys malibu takes a little longer, dont think hes quite got the hang of starting a carbureted motor, he goes thru the starters, ill have him try the vette starter, thanks for the info
c10srule is offline   Reply With Quote
Old 11-30-2012, 04:22 PM   #13
67swb72klb
67swb72klb's Avatar
i dont know if they are the same starter as the vortec but i have one from the older 88ish tuned port motors its a smaller size starter and it spins the 327 over real fast
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 11-30-2012, 05:56 PM   #14
BCOWANWHEELS
Also a note on the gear reduction gm starters there almost $200.00 "if" you have a core to trade in. The aftermarket gear reduction starters are all china. With the vette starter you can swap in your old starter as a core with no upgrade. Dont forget tere lifetime guaranteed and for $45.00
Old 11-30-2012, 06:19 PM   #15
cleszkie
cleszkie's Avatar
I totally agree with using a gear reduction mini starter. Have a Powermaster unit on my Blazer. However, I still think it is a good idea to run a remote starter solenoid since even a mini starter solenoid can suffer from heat soak issues. I run a remote solenoid and have never had a heat soak problem. It also provides a nice, easily accessible "keyed power" source for other underhood accesories such as cooling fans.
cleszkie is offline   Reply With Quote
Old 11-30-2012, 07:31 PM   #16
dhaymaker
dhaymaker's Avatar
I don't mind a little whine, as someone said, for the amount of time it takes to fire the engine. Besides, it simply has to whine a hell of a lot less than my ex-wife!!
don
"The DRBMan"
2014 Audi A4 (The Wife's Daily Driver)
2017 HD Ultra (The Cruiser)
2003 HD Fatboy (The Ride)
2001 Chevy Suburban (Another back up!!)
For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!!
dhaymaker is offline   Reply With Quote
Old 11-30-2012, 09:13 PM   #17
MalibuVLX
The whine is short lived and our truck cranks in a milla second. We had issues w/ old style Delco starters once they got a little age on them. The heat soak from the headers killed em quick. The mini starter has had no such issue and very happy with performance thus far. I am pretty sure it is a China or the like made, but couldn't afford the powermaster version. I would love to have one of those, and the high output alternator too. It did take a little getting used to, but don't even notice it now.
Old 11-30-2012, 09:50 PM   #18
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Saved for future reference, just in case.
I'm almost afraid to say this 'cause I don't want to jinx myself..... I'm still on the original starter. I did replace the Bendix drive several years ago b/c the gear failed to engage occasionally, but that's it. Still workin' just fine. Original alternator too.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-30-2012, 09:53 PM   #19
LEX
LEX's Avatar
I'm sold on the O'Reillys starter. My nearest location has them in stock and with lifetime warranty, why not?
Old 11-30-2012, 09:56 PM   #20
HotRod C/10
HotRod C/10's Avatar
good info!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 12-16-2012, 11:46 PM   #21
Willie496
Question about starters. I have a 1971 4 speed 4x4. I bought this as a project truck and it did not come with a starter. It looks like the starter has three bolts that run into the bellhousing horizontally if that makes sense. We tried an older starter that bolts up through the bottom into the block like my Camaro, for example. When we tried to start it the engine turned over and the gear would not disengage from the flywheel.
What could my problen be? The wrong starter? This is a 1986 350 block.
Thanks, Willie
1969 GMC 4x4, 4 speed, 350 Fleet Side in progress.
1969 Camaro SS 427 Cortez Silver. owner since 1974
1964 Chevelle 4 Door, 427 Big block,Turbo 400
1/4 Mile 10.52 @ 125.85 mph. 1.39.1 60'
1982 Crew Cab 3+3, 2WD 3.21 Locker, 468/4 speed
1969 C30 4 speed (IL6) future build.
Willie496 is offline   Reply With Quote
Old 12-17-2012, 01:38 AM   #22
oklalawnboy
oklalawnboy's Avatar
Got one on mine, I don't notice the whine but I'm deaf in one ear and can't hear out the other....
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 12-17-2012, 09:00 AM   #23
MARKDTN
I used to say the same thing until I looked objectively at the facts. To me the mini-starters are absolutely the way to go! That big old heavy beast may have a lifetime warranty, but you won't like it very much when it dies at a bad time. Starters and alternators have come a long way since 67-72. True the original 80s/90s CS130 alternators were less reliable than the SI series, but the CS144 and newer CS130D ones are quite robust. My '01 Tahoe has almost 250K miles and has never had a starter yet (or water pump or transmission). The alternator went to 199K. You won't find that on the big starters. Also, GM gear reduction starters are nothing like Chrysler starters of the day. You don't have all that noise. They are also much more resistsnt to heat and have less clearance issues. Give one a try next time you need a starter. For those with points, you can use a relay to overcome the lack of a coil terminal.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 12-17-2012, 12:46 PM   #24
Andy4639
Old member
Andy4639's Avatar
Wink Re: Small block starter tip of the week.....
Here is a old post I changed my starter with. About 2 years old and not one problem with it.
http://67-72chevytrucks.com/vboard/s....php?p=4144488
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-18-2012, 02:52 PM   #25
67chevemall
67chevemall's Avatar
I use the CVR high torque mini and love the sound it makes....and it all ways works, no fuss
http://cvrproducts.com/
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
