#26 |
Re: What sway bar to use ?
Brad Man 72 you did put that swaybars REDUCE traction which I would assume is a typo. Its OK we all do it.
Anyway................Any swaybar you intall properly is going to help. Each claim to be better but they all do the same thing on a street driven truck. If you were building a track truck with custom built frame and tubeular control arms set up for track use only than style of swaybar would be a issue. All the above suggestions are correct but I would say for your use find the one that you can afford and put it on. You wont tell a difference from a CPP or high dollar aftermarket.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
#27 | |
motor exploder
fwiw, I have a CPP bar on my truck with the CPP mounts for lowered trucks. It fit okay, had to really hold my mouth right to get everything to line up. There may be better bars out there, but the CPP one is relatively inexpensive compared to he RideTech Musclebar.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#28 |
Some good info here guys, keep it up.
#29 | |
#30 |
just some info if you dont mind, have a '69 c10 with rear sway bar, looking for bushings but bar was installed before i cgot the truck, can you tell me the part number/brand for rear bar.
Thread Tools | |
Display Modes | |
