12-19-2012, 10:22 PM | #1 |
What sway bar to use ?
I want to fit a sway bar to my 69 c10, what can you recommend, I have looked at the ridetech, just wondering what else is out there.
Thanks Mark. Posted via Mobile Device |
12-19-2012, 10:33 PM | #2 |
Re: What sway bar to use ?
I've intalled a couple of original ones and they work just perfect. Couldn't ask for a more noticeable improvement from single part.
-Scott- |
12-19-2012, 10:36 PM | #3 |
Cruzin
i got one off a mid 70's 3/4 ton truck for 20buck at the yard, they all bolt up through 87 models i just bought the lowered truck mounts from ece
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
12-20-2012, 01:08 AM | #4 |
70+ ( Old Skool Club )
For the price a frontt sway bar is the best bang for the buck add-on you can do. I put a 1 1/4 inch from a 70's Camper Special 3/4 ton and added the polyurethane bushing and brackets for lowered trucks that ECE sells and could fel the difference in handling right away.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-20-2012, 11:24 AM | #5 |
Take a look at CPP they have bolt on Sway-bars for your truck.We sell the complete line of CPP parts.We run a Special on there parts YEAR ROUND.
You can call us at the shop or p/m me or e-mail me (805)485-0382 justin@scottshotrod.com Justin |
12-20-2012, 11:26 AM | #6 |
how about a good fitting rear sway bar.....?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
12-20-2012, 02:56 PM | #7 |
the boat guy
Their is no best sway bar. Sway bars reduce body roll and reduce traction. Its best to do quite a bit of reading and knowing where you want to end up before spending a bunch of money.
Stock bars from square bodies work great for the money. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
12-20-2012, 03:12 PM | #8 |
since when does a sway bar reduce traction???
70 C10 working on a LSx swap 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
12-20-2012, 09:12 PM | #9 |
What benefit do the lower mounts from ece do? Is that needed? Or how much drop do you need to have before this are required?
Thanks, Ryan Posted via Mobile Device |
12-20-2012, 09:35 PM | #10 |
F body Camero.
I got mine at pick and pull $20.00 with all the brackets. 1 1/4 inch. dont waste your money buying CPP, or hotchick's, or those other high end bars. IMHP
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
12-20-2012, 10:10 PM | #11 |
I used a C-10 sway bar don't no year, 67-72 from a V8 in my 67 short fleet straight 6, works great notice right away. Don't know if there's a differents between sway bars when it's for a V8 or L6
12-20-2012, 10:54 PM | #12 |
[QUOTE=ryans69chevy;5769642]What benefit do the lower mounts from ece do? Is that needed? Or how much drop do you need to have before this are required?
Thanks, Ryan [size=1]Posted via Mobile Device[ A popular drop is 4 inches in the front and I think with that amount of drop ( or more ) and using stock brackets which are I'm sure are another 4 inch drop you could hit the sway bar on curbstones etc. I got the lowered brackets cause I needed new brackets and they weren't expensive and unless you get down on your hands and knees you cant see the sway bar on my stock height truck even with the 29 inch high tires, and I like that you can't see the sway bar. Posted via Mobile Device
12-21-2012, 04:28 PM | #13 |
the boat guy
I'm sorry I thought this was common suspension tuning knowledge. Why else would sway bars come in sizes less than 4", why that when allowed racecars use adjustable sway bars, when you have 4 springs pushing down evenly on 4 tires you have the most traction available.
Blah blah blah, roll center, yada yada yada, camber curver, wonk wonk wonk, tire deflection, knuck knuck knuck, chassis flex, yougettheidearight? If not go to the suspension side of the forum and read "make it handle" Posted via Mobile Device
12-22-2012, 05:17 PM | #14 |
Thanks for all of the replies, much appreciated. I should mention is is on air bags and rides quite low. I see that hotchkis has a 25% off sale on at the moment too.
12-22-2012, 08:23 PM | #15 |
12-22-2012, 08:27 PM | #16 |
Good looking truck
12-22-2012, 09:29 PM | #17 |
I have Hellwig bars, front and rear .. The rear one is a little bit of a pain to mount but overall I really like it.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
12-23-2012, 05:28 PM | #18 |
Purchase a front sway bar from POL & had to modify the mounting brackets to get it to fit.I think Helwig would be better quality.You get what you pay for.
12-23-2012, 05:39 PM | #19 |
Moderator
I have an OEM sway bar on my truck, works just fine.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
12-23-2012, 05:43 PM | #20 | |
I had both front and rear from CPP and they worked great.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
12-23-2012, 06:31 PM | #21 |
So with a 2.5 drop in front do you think the lowered brackets are needed?
12-23-2012, 06:42 PM | #22 |
Moderator
No.
01-16-2013, 08:17 AM | #23 |
01-18-2013, 05:08 AM | #24 |
I'm also trying to figure out what to do for the rear as there are a few different types. For example, Hotchkis has 2 different ones. Do they all perform the same?
68 short step, 406/700r4, 9" w/discs. |
01-18-2013, 07:58 AM | #25 | |
Old member
For the rear I bought a Z-28 rear sway bar. It takes a little work but it was worth it. You need spacers for the frame mounts but they are easy enough to make. I have a extra set by the way. I bought the clamps for 3" exshaust to clamp the bar to the axle.
