Old 07-11-2013, 10:57 AM   #26
Jamminjohn
Re: 68 C20 LWB parting out
Originally Posted by Steve Cole View Post
Did you see if you had the TH400 harness? I couldn't do 50 on the fan but maybe the fan and harness together.
Thanks.
I ran out of daylight, Ill try and look again tonight
if I find it, $50 for both is what I was going to ask for also.
Jamminjohn is offline   Reply With Quote
Old 07-11-2013, 11:02 AM   #27
Jamminjohn
Originally Posted by swamp rat View Post
How much for the deluxe running lights? close up pics? I need a set.
I did not see this post until now, Ill look tonight when I get home and post pics w/ price.
thanks
Old 07-11-2013, 11:08 AM   #28
Jamminjohn
Originally Posted by nobolt View Post
what shape is the cab in? rust issues? bondo?
There is some rust, I dont think that there is any bondo, but im not %100 sure.
Here are a few pics
Old 07-11-2013, 11:10 AM   #29
Jamminjohn
Originally Posted by 68shortfleet View Post
I could use a cross member out of that frame if you are cutting the frame up. It is the furthest rear cross member that is riveted into place.
Let me know if you would be interested in cutting this out, maybe cut the frame right in front and right in back of it unless you have a blue wrench to get the rivets out without hurting the cross member.
Ill let you know when I start cutting/dismantling, Might be this weekend.
Old 07-11-2013, 12:54 PM   #30
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I would be interested in piece of the front frame rails of you start cutting up the frame... Mine was cut off to put a roll pan on... considering going back to a stock bumper... only need 5 or so inches off each side...
chevyguy_72 is offline   Reply With Quote
Old 07-12-2013, 11:00 AM   #31
Jamminjohn
I wasn't able to find it.
I had someone looking at the trans last night and he said it looks like a 700 something.
Old 07-12-2013, 11:02 AM   #32
Jamminjohn
I started cutting last night. Ill probably cut all of the crossmembers out tonight.
Old 07-12-2013, 11:03 AM   #33
Jamminjohn
I will most likely be cutting tonight, Do you have an exact measurement that you need?
Old 07-12-2013, 02:09 PM   #34
chevyguy_72
Vintage Evil
I will measure when I get home.
Old 07-13-2013, 07:35 AM   #35
chevyguy_72
Vintage Evil
I would say behind the core support mount forward would do it
Thread Tools
Display Modes
