09-01-2017, 10:26 PM | #26 |
Re: Headliner trim or not to trim?
The thing with magnets is you still have to use adhesive. So, you have two possible failures, magnet or glue. The 3M (super?) weatherstrip adhesive did the trick for sure on the few I've done. I can check out in the shop because I always keep that stuff around. It's the yellow goo like contact cement, not the clear. It's good in heat because weatherstip gets hot.
09-02-2017, 12:36 AM | #27 |
I did the extra strength velcro, made for outdoors on brick etc. Been there 10 day. So far so good
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
09-02-2017, 07:35 AM | #28 |
Weatherstrip is interesting...didn't think of that one...got to go research that
as far as adhesives go...I was thinking about http://www.loctiteproducts.com/p/cnt...Conditions.htm says it's good to 248 degrees.... this guy says it gets to 192 degrees in Phoenix in summer https://www.youtube.com/watch?v=nnpSABil6zg Meguires thinks the metal temp will stay below 200 degrees http://www.meguiarsonline.com/forums...MLXT48hOuhh.97
JMC1965 1967 C20 LWB
09-02-2017, 09:13 AM | #29 |
What I have out there now is Permatex Super Weatherstrip Adhesive. Pretty sure I used 3M years ago when I did it. But Permatex is good stuff. Spray adhesive goes on so thin and even, which is great in many cases. But you lay beads down and those are the first points of contact that get spread when you press on it. Spray adhesive you have to work fast. This stuff you are supposed to go slow, let it tack up first. It's important to press it flat. I think I used plywood on the ceiling with 2x4s to the floor overnight
Thread Tools | |
Display Modes | |
