Old 03-04-2014, 03:05 AM   #1
texjake
texjake's Avatar
Headliner trim or not to trim?
I hope this is not a dumb question. I have been thinking of installing a headliner in my '68 truck. Mine did not originally come with a headliner & I have seen the other year model trucks that did come from the factory with one & they have the small clip holes in the cab roof to hold the trim in place. Can I install mine without the trim and will it still look ok? I know I can use the 3M spray adhesive to hold it up there forever - I hope. But I just want to make sure it will look alright without the trim because I really don't want to cut holes in my cab roof if I don't have to. And if anyone has any pics of their headliners without the trim please post them so I can get an idea of how it will look without the trim.
"Now all I need is a shop to go with my shop vac!"
texjake is offline   Reply With Quote
Old 03-04-2014, 09:20 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Headliner trim or not to trim?
3m spray can adhesive won't work it will fall down the first time it gets hot from the sun , if you want to mount it and not have it fall use windshield setting urethane in a caulking gun and brace it over night it will stay there forever and you can always go back and peel the urethane back off but you would destroy the headliner in the process .
Grumpy old man is offline   Reply With Quote
Old 03-04-2014, 09:52 AM   #3
RexDodge
I used a 3M product on mine. It was the heavy fabric type (spray) and I remember it said headliners on the can. Worked great. Sprayed on both surfaces, let it glaze, apply another light coat, position, stick, pulled back slightly (let it flash) and stick down. I used a counter top (sheet vinyl) roller to finish it off. No problems. I am still looking for my trim ring...a year later
RexDodge is offline   Reply With Quote
Old 03-04-2014, 10:50 AM   #4
ZOOKEENEY
ZOOKEENEY's Avatar
Hope this helps you....
Eric K
ZOOKEENEY is offline   Reply With Quote
Old 03-04-2014, 03:00 PM   #5
texjake
texjake's Avatar
Thanks for the pic Eric, but my neck is hurting trying to look at it, at a 90 degree angle.... But it still looks great without the trim.
Old 03-04-2014, 09:25 PM   #6
atm70chevy
atm70chevy's Avatar
I really like your door panels. I have been looking for something like that. Are those custom made or did you buy them somewhere?
atm70chevy is offline   Reply With Quote
Old 03-04-2014, 11:19 PM   #7
ZOOKEENEY
ZOOKEENEY's Avatar
Thanks, they are Marquez Design.
Eric K
Old 08-31-2017, 06:39 PM   #8
JMC1965
JMC1965's Avatar
Great look. How did you get the headline to stick?
JMC1965
1967 C20 LWB
  • 350 (ATK-HP32) / FiTech EFI
  • 4L60e / 4 wheel disc brakes
  • 20" American Racing VN327 & 245/50/20 Michelin
JMC1965 is offline   Reply With Quote
Old 09-01-2017, 06:19 AM   #9
I agree, truck looks great. It does help for showing what a headliner looks w/o trim, but no help at all on how it is fastened, glued, whatever.
I have done this on trucks and I squiggled 3M weatherstrip adhesive on which held it just fine. Never had one come loose.
Old 09-01-2017, 07:42 AM   #10
JMC1965
JMC1965's Avatar
I'm sort of thinking about trying the magnet approach. I might have to do my own science fair project and see what happens.
JMC1965
1967 C20 LWB
Old 09-01-2017, 09:13 AM   #11
Geos 72
Geos 72's Avatar
I was thinking of putting one in but didn't want the trim either. I was thinking of trying some heavy duty Velcro. Wonder how that would work.
1972 Chevy C10 Cheyenne shortbox/ 350, 3 speed on the floor
Geos 72 is offline   Reply With Quote
Old 09-01-2017, 09:47 AM   #12
JMC1965
JMC1965's Avatar
I think the Velcro would work (never tried it but searched the forum and other people have used Velcro for holding stuff)
I like the concept of the magnets just to simplify removal. I think my fall project might be to play around with this...
off the cuff I'm thinking that a headliner, magnets, adhesive (to hold magnets to headliner), and possibly some insulating material to reduce vibration might do the trick
we'll see....got to finish the big mods right now.
decent reading on magnets
http://www.magnetsource.com
who knows...I might be overthinking this and velcro is the way to go
JMC1965
1967 C20 LWB
Old 09-01-2017, 11:01 AM   #13
Geos 72
Geos 72's Avatar
I guess the only thing to do is to try both ways and see which one works the best. I'd like to try the velcro but not sure if that would be this year.
Old 09-01-2017, 11:09 AM   #14
Coley
Coley's Avatar
I put a headliner (no trim) in my other truck years ago....looked great and looked exactly like it belonged there.
I can't remember what I used to glue it to the inner roof....but it held and again, it looked great.
At the time I had no interest in trying to drill a bunch of holes, some of them square I think...in the inner roof....nope.
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-01-2017, 11:13 AM   #15
dflarsen77
You can get a 2' by 8' roll of flexible magnetic sheeting for $30 or so. I've used it for other stuff. I haven't tried to cut it, but it's only .030 thick. Stick your headliner over the sheet, cut to size, then glue it. But why not just glue it directly to the cab anyways? Everything else seems like one or more steps? Is the idea so you can remove it if the mood strikes you? I'm planning to do a headliner with no trim, thanks for the tip Grumpy and that pic is a great reference Zookeeney!
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
Old 09-01-2017, 12:37 PM   #16
JMC1965
JMC1965's Avatar
I also want the headliner without the trim...plus...I don't want to drill into the metal either....so it's both of those for me.
In my case I thought why not just make it where I don't have to clean up the glue if I really want to change the look later on
JMC1965
1967 C20 LWB
Old 09-01-2017, 01:20 PM   #17
Geos 72
Geos 72's Avatar
Soon as I get the chance to get the headliner I think i'm going to try the velcro. I think three or four heavy duty strips 4" wide and the length of the headliner might work, then you will be able to remove it.
Old 09-01-2017, 01:30 PM   #18
CharlieBrown
CharlieBrown's Avatar
I did the Velcro on mine....no trim...its been on for 6 months or so all is well
1972 Cheyenne Super..owned since 1978
1972 Surburban 4x4
1972 Cheyenne 4x4 3/4 ton.....sold
1972 Cheyenne 2wd...named Death Row
CharlieBrown is offline   Reply With Quote
Old 09-01-2017, 01:31 PM   #19
JMC1965
JMC1965's Avatar
do you have any pics?
JMC1965
1967 C20 LWB
Old 09-01-2017, 01:31 PM   #20
notsolo
notsolo's Avatar
Follow up with some photo's when you get yours done. I am also going to put headliner back up, adhesive failed and all the trim clips broke on mine taking them off. Faded plastic chrome doesn't look all that great anyway.
notsolo is offline   Reply With Quote
Old 09-01-2017, 01:33 PM   #21
JMC1965
JMC1965's Avatar
will do...got to get the big stuff done right now (EFI, new OD trans, gas tank relo)...should be able to get to this in the fall
JMC1965
1967 C20 LWB
Old 09-01-2017, 01:42 PM   #22
Geos 72
Geos 72's Avatar
CharlieBrown, thanks for the info, it was good to know.
Old 09-01-2017, 01:56 PM   #23
CharlieBrown
no pictures with me....but I bought a roll a at Lowes...it was 21/2 wide and I used all of it.
I have new trim but my cab doesn't have the square holes either...but I am thinking about cutting the clips off the back of the trim and putting it up with the trim screws around the center section.
many trucks I have seen with the factory headliners sag ...so I think the Velcro would be the thing to do even with the factory holes.
1972 Surburban 4x4
Old 09-01-2017, 03:33 PM   #24
StingRay
StingRay's Avatar
Sometimes the adhesive on the Velcro doesn't hold in higher temps. If it does the vibration of driving will weave the Velcro together to the point you almost can't take the Velcro joint back apart.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 09-01-2017, 07:52 PM   #25
Geos 72
Geos 72's Avatar
I guess all we can do is try different ways to see what works the best.
