Old 12-19-2022, 10:22 AM   #26
Yamariv
Yamariv's Avatar
Re: 69-72 c10 350
Sure there is. Just do as you planned, flat tops, better heads, and cam. Those were the things that defined "smog motor". Anything else is added externally.
So the 74 block is worth getting you think? I was going to rebuild it anyway over the next couple years.
1971 Chev C10 - 250ci L6 w/3 speed on the floor
Upgrades: Power Steering
3 Core Radiator
7 Hole Gauge Cluster
Power Brakes (Incoming!!..)
1971 350 (Incoming!!..)
Yamariv is offline   Reply With Quote
Old 12-19-2022, 12:54 PM   #27
SCOTI
SCOTI's Avatar
Re: 69-72 c10 350
Yes... The older blocks are worth rebuilding/tweaking.
'Newer' blocks from the Vortec/L31 (96-00) era are decent as well since they have the roller cam provisions & 1pc crank seal set-up (less leak prone).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Thread Tools
Display Modes
