69-72 c10 350
How were these C10 truck motors set-up from GM? Were they flat top piston/large chamber heads? Dished piston w/large chamber heads? Dished piston/small chamber heads?
I can't remember when GM started making changes on the truck sbc's for emissions/gas compliance needs.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-14-2022 at 12:53 PM. |
Re: 769-72 c10 350
I have no idea as to truck changes compared to passenger vehicles however, 1971 (and later) was the year engines had reduced compression. Head chamber sizes may have changed a couple years before dished pistons?
You may find better info by looking up head castings and the specs. Bob |
#3 | |
Re: 769-72 c10 350
I plan to look @ a factory late 60's early 70's 350/350 C10 pull-out combo to use for a strategic flip scenario. Knowing how these came from GM potentially helps w/the strategy.
Active Member
![]() Join Date: Jun 2021
Re: 69-72 c10 350
All 3 of the 350 I have worked on recently have flat top pistons with valve pockets and large chamber heads..they were 71 to 76 engines
Re: 69-72 c10 350
Well.... I'll find out soon enough. I'll have this 350/350 combo in the next several weeks.
Re: 69-72 c10 350
Most of the early truck and passenger 350s I have seen had flat-top pistons with valve reliefs. In fact, I may be wrong, but I don't remember any stock 350s having dished pistons-at least not any I have torn down.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
#7 | |
Re: 69-72 c10 350
Thanks for the info as this sort of stuff is exactly what I was curious about. My C10's were 67/8's w/straight 6's. My old '74 had a 350/350. I never cracked open that 350 since it got the job done as-is. I figured if this 350 has flat tops, it should have decent (well, better) compression vs a dished piston/76cc head combo.
![]() Join Date: Nov 2013
Re: 69-72 c10 350
I think 72 was the first year that the pollution laws started to effect the 350 specs
Any 350 that I ever disassembled before that had flat top pistons with 4 valve reliefs. Only the performance engines got the higher compression heads so most stock 350s would run on regular gas. Of course it was leaded gas and better than today's regular 87 octane.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer .............
#9 | |
Re: 69-72 c10 350
'71 C/20 350/T350. |
Re: 69-72 c10 350
I googled for sbc head data. 76cc/large chamber heads were in production by '71. Prior to that was mostly 64cc stuff.
![]() Join Date: Jul 2000
Re: 69-72 c10 350
Here's what I found in various places:
Truck 327s had 64cc heads, and it looks like some even had 70cc or 76cc. However the only 350 I can find with 64cc heads was the 370hp/LT1 350, used in the Z28 and Corvette. Compression ratio was around 11:1, as I recall. 69-72 passenger car and truck 350s had 70, 75, and 76cc heads. Possibly with flat top pistons but probably with dished. Compression was probably around 9:0, and then may have dropped a little in the early 70s.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#12 | |
Re: 69-72 c10 350
#13 |
Re: 69-72 c10 350
I know in truck 350s the HP peaked in '70 and by '72 they dropped a lot of HP. I think in '72 what came later had just begun. I see where a 70/71 350 could have 255hp and in '72 it dropped to 175hp max
#14 |
![]() Join Date: Dec 2013
Re: 69-72 c10 350
Almost 5 years to the day I brought home this 350 I found on the right day from a friend of a friend who was parting out what was left of his project truck that he wrapped around a tree .
![]() Originally Posted by bruceman1968 Hey Grump, You got everything you need there to positively identify your block. VI208TBC 3970010 L10 L10 is the casting date L = December 1 = December 1st 0 = 1970 Your block was cast on December 1st 1970 3970010 in 1970(or 1971 see below) is a 350cid. VI208TBC is V1208TBC I's used for 1's is very common when found stamped on Blocks. 1208 = December 8th Your Block was cast December 1st and assembled on December 8th in 1970. Casting Date codes are the day, month and year they say they are, but Suffix codes go by Model Year. Your block is December of 1970 which is the 1971 Model Year. So when you look up TBC you have to do it for 1971. In 1971 TBC = 350cid, 255hp, 350auto, LS9, 4bbl, 10,20 C or K So you have a 1971MY 350 Truck motor. Great price. BTW This thread shows what I found inside . http://67-72chevytrucks.com/vboard/s...d.php?t=752595
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 12-18-2022 at 10:01 AM. |
#15 |
Re: 69-72 c10 350
After 5 years of constant project creep I'm still working on it . I've come close to pulling it back out and just to find out what pistons are in it , But I can't tear apart a good running engine . Maybe it's time I bought a bore scope ?
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#16 |
Re: 69-72 c10 350
For my '67 project I have a freshly rebuilt '68 truck 327. Freshly rebuilt in '07 that is. I plan to crack it back open now. Back then I used 64cc iron heads and the choice of cam was based on using the TH400. An M22 crept up so I want to do some top end changes now anyway.
#17 |
Re: 69-72 c10 350
The reason for the HP drop in 1972 is that they started listing net HP as opposed to gross. Basically the same engine.
#18 |
![]() Join Date: Jan 2003
Re: 69-72 c10 350
Rent one at Autozone. Ends up being free after you return it.
1969 307, t3501950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
#19 |
Re: 69-72 c10 350
If there are actually any left, I'd like to tear apart a previously unmolested 69-70 truck 350 to see piston type, gasket thickness, and actual deck height. You can easily tell combustion chamber volume by removing a valve cover and looking at the casting number.
I say "truck 350" but C20s and C30s may have had smaller camshafts along with lower static compression than C10s, achieved with either dished pistons and/or 76cc chambers.
#20 |
Re: 69-72 c10 350
I'm looking for a period correct"ish" 350 for my truck and have been watching this thread closely. So if I'm understanding this right, a mid 70's low compression block was the same as the earlier high compression block, it was just the heads and pistons that changed in the smog era for low compression?
I have a line on a 1974 350 out of a Monte Carlo, if the above is true then maybe I should grab it and put high compression heads on it and flat 1970 pistons and I'm good to go?
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
#21 | |
Re: 69-72 c10 350
#22 |
Re: 69-72 c10 350
So no easy way to getting her up to 1970 Compression and specs w/o too much money invested?
#23 |
Re: 69-72 c10 350
Just found this at the GM Heritage Center website:
There were several 350s available in 1969. The TurboFire 350 had 9.0:1, 10.25:1, and 8.0:1 compression depending on the vehicle. The 10.25:1 engine was listed as an available option only in the El Camino. The High Torque 350 had 8.0:1 and 9.0:1 compression and was used in HD trucks. Start here with pdf document page#52: https://www.gm.com/content/dam/compa...olet-Truck.pdf You can find all kinds of specs here.
#24 | |
Re: 69-72 c10 350
Somewhere In my searches I ran into ratings for Gross and Net numbers listed for the same engines, but I forget where that was! One that I think I remember is a 307 was rated 200hp Gross and 155hp Net.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 12-19-2022 at 11:30 AM. |
#25 |
Re: 69-72 c10 350
Sure there is. Just do as you planned, flat tops, better heads, and cam. Those were the things that defined "smog motor". Anything else is added externally.
| Bookmarks |
