Old 05-27-2008, 06:52 PM   #51
ChevyDude
Re: Headers for lowered Big Blocks
Thanks Mike...gonna use these on my Overkill project!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 07-29-2008, 08:56 AM   #52
aggie91
I'm just glad to be here!
aggie91's Avatar
Thanks for the info Fizz, I was going down this same path a few years ago, but my job/house/kids took over, now maybe this year I will be back at it...
They look like they fit real well. Do you have any pics with the exhaust pipes hooked up to the collectors?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-29-2008, 12:06 PM   #53
Frizzle Fry
Frizzle Fry's Avatar
Project link in my sig
Frizzle Fry is offline   Reply With Quote
Old 07-30-2008, 07:45 AM   #54
aggie91
aggie91's Avatar
Thanks, I found that after I posted my question...I like they way these look and your exhaust is killer.
Karl
The LST Challenge:
Old 08-05-2008, 07:50 PM   #55
umwtnt
umwtnt's Avatar
Hey Fizz, its been a short time since you installed the patriots, Are you still happy with them? How is the coating looking? Overall they look like a good purchase and look good installed. thanks for the info.
umwtnt is offline   Reply With Quote
Old 08-05-2008, 08:28 PM   #56
jkade
jkade's Avatar
Them where for a chevelle and came from summit, minor trimming on pass side frame rail.
95% sure they where patriots.
jkade is offline   Reply With Quote
Old 01-28-2009, 02:17 AM   #57
PrettyRicky
what kinda long tubes are you guys running. i see a set up super comps for a chevelle, what else?
PrettyRicky is offline   Reply With Quote
Old 01-28-2009, 05:44 AM   #58
royo
royo's Avatar
http://www.sandersonheaders.com/index.php I was thinkin bb1
nickle and dime
royo is offline   Reply With Quote
Old 01-28-2009, 02:44 PM   #59
Frizzle Fry
Just saw this... Haven't driven it much so they look brand new!
Old 01-28-2009, 02:56 PM   #60
Prostreet 72
Prostreet 72
Prostreet 72's Avatar
I have Hooker Super Comp headers on my truck. The only time I had an issue was with my driveway breakover angle. My truck had 3" lowered springs and Belltech 3" lowered spindles in it at the time. I put stock springs in and the issue went away.
As for the pipes, I have 3" pipe all the way back. The trick for me was to cut two clearance holes in the center crossmember for the pipes to pass thru. This kept everything above, or only slightly lower than the frams surface.
Prostreet 72 is offline   Reply With Quote
Old 01-29-2009, 03:11 AM   #61
PrettyRicky
do you have any other pics of underneath your truck. and will all chevelle headers work by hooker?
Old 01-29-2009, 10:10 AM   #62
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have the same headders and have not driven them a mile and the coating is starting to dull but other than that they still look great..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-11-2009, 03:21 PM   #63
Frizzle Fry
Bump for people who have PM'ed about this topic.
Old 02-20-2010, 08:53 PM   #64
dan468
dan468's Avatar
Do you think these will clear a factory Z bar for a manual trans?
thanks
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 03-26-2010, 05:56 PM   #65
35spline
35spline's Avatar
I just received a new set of the Patriot Clippster Headers (p/n 8013H) and found the driver's side 3/8" flange badly warped. Back to Summit racing they go. Has anyone tried the headman headers elite p/n 68618?
35spline is offline   Reply With Quote
Old 03-28-2010, 12:05 PM   #66
FRENCHBLUE72
PROJECT 7DEUCE
Thats a bummer I have mine partiots from summit and they are killer..
MEMBER #6377
Project "7DEUCE"
Old 03-28-2010, 12:27 PM   #67
kgt
Hooker super comps, 2 primary tubes, 3 1/2 inch collectors and 3 inch exhaust tubes all the way back. lowering spring in the front and removed rear springs and shocks and used a coil over street rod kit in the rear. clears my steep driveway..
kgt is offline   Reply With Quote
Old 03-28-2010, 12:56 PM   #68
cpetersen
cpetersen's Avatar
This guy makes a neat set, they are in the frame rails.
Originally Posted by cpetersen
Do you still make those headers? How thick are the flanges? Can you make them with a 3 hole flange at the bottom? They look like nice headers, did you have any problems with the brake lines on the driver side inside the frame rails? Thanks Clayton
cell
Hello Clayton, Yes we still make the headers. The flanges are 3/8 and they come slip fit collector. Brake lines that run on the inside of the frame will have to be modified or converted to outside framerail lines. Thanks Steve
Slip fit? Do they have a big clamp that holds the pipe on. The problem we have in AZ is the heat that is generated under the truck and if you lower the truck. The heat doesn't escape and you have problems with cooling. Crap i have some decisions to make, lol its always something. Do you have a phone number? How would you get paid?
Yes, You can use a clamp we recommend band clamps or whatever your local exhaust shop wants to use. You can give us a call at 425-251-0210 8am - 5pm pst. We accept visa and mastercard. Thanks Steve
cpetersen is offline   Reply With Quote
Old 08-01-2010, 10:40 PM   #69
dan468
dan468's Avatar
I just ordered the uncoated ones in case mods have to be made. Has anyone tried these with a manual trans?
Dan
68 C-10
Build thread
Old 08-03-2010, 03:17 AM   #70
bigblock68
bigblock68's Avatar
Hedman chevelle 3/4 length,got them from jegs.check em out at pir next week..heading down to reno for han in the morning!!
bigblock68 is offline   Reply With Quote
Old 08-03-2010, 06:10 AM   #71
lost wages
lost wages's Avatar
heres mine
http://67-72chevytrucks.com/vboard/s...d.php?t=234160
lost wages is offline   Reply With Quote
Thread Tools
Display Modes
