![]() Join Date: Aug 2005
Headers for lowered Big Blocks
Any recommendations? I'm looking for something 3/4 length or so that won't hang as low as my current full length set.
Re: Headers for lowered Big Blocks
yeah I would be interested in the answer for this also!!
1970 C10 Stepside (soon to be a 68 w/PS/PB/S&W back-half narrowed F**D 9inch w/Discs) 66 427/435 corvette motor (hopefully 871 Blower) 66 M21 4 speed (swapped in a built TH400) 31/16.5/15 Mickeys (soon to be 29.5X18.5X15 MT) 1972 C10 Stepside Pro-Street 1988 bed 3" Top Chop Custom Red Pearl paint w/overlapping Ghost Flames P/S P/W P/B P/DL P/door open Everything Shaved Frenched antenna 461CI BBC BDS Blower 1100 Dynoed HP TH400 Super Heavy Duty Full Back-Half Narrowed 12 Bolt 4:10 |
TOTY 2006
![]() Join Date: Dec 1999
Same here... I have a 402 going into a 67, and do not want any exhaust running lower then the frame....
I have been looking for that answer for 7 years
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
I sent them an inquiry. We'll see what they say...
-Praise the Lowered-
Race-N-Jason ('71 Chevy C-10 LWB 454/TH350) ('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual) |
I have Sandersons BB3 3/4 length for a Chevelle in my truck. IIRC, I trimmed the pass side rail 1/8" for insurance only. They cleared, but I figured the 468's torque would move the factory rubber m.mount isolators a little bit & I didn't want them to hit.
I punched holes in the crossmember, welded in the large diameter pipe like many on here & have 3" mandrel exhaust to the rear end that's 'invisible' w/the exception of the oil filter area (you can see that pipe through the fenderwell opening). You may not be able to see it..... but you could definitely hear it.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-21-2007 at 07:42 PM. |
#9 | ||
Did you go over the tranny xmember? Any pics? |
I used a set of 69 Camaro BBC by Hedman.
Yes sir. Over the trans crossmember (fabricated crossmember that's very similar in construction to what's now offered from ECE or Perf-OnLine) and a straight shot through the boxed trailing arm c.member.
If you get down on the ground & look @ the truck from the side, you don't see any exhaust @ all. As for pics.... I have so much crap in/around this project that it will take a few days to get some.
http://67-72chevytrucks.com/vboard/s...d.php?t=234592
Check out that old thread of mine, those are patriot clipsetters from summit for a early 70's chevelle or malibu. Only had to do minor trimming and the are quality headers. You could lay frame with them on there. |
#13 |
Location: vacaville ca, because it as far from indy as i can be
stay away from the hooker competions[not super comps] they hang the full diam below the frame.
#14 | |
Actually, if I didn't have other things in the way, I could have easily routed them above and through the crossmembers. My current Transmissioin linkage was in the way. I love these Hedmans. The only thing I regret is not opting for the ceramic coating. They have a new collector design that is more forgiving, and allows for different approach angle of the exhaust pipe. Just something else to consider....
Race-N-Jason ('71 Chevy C-10 LWB 454/TH350) ('07 Dodge Ram 2500, 5.9 Cummins/6-speed Manual) Last edited by race-n-jason; 06-22-2007 at 12:04 AM. |
#15 | |
or $349.95 for 1-7/8" primaries... Link |
#16 |
Ok if these fit they look like a better deal. They have 3/8 flanges instead of 1/4" as well as 14 gauge instead of 16 and ball flanges. Al that for $299.95 with only one questionable thing: They say they are "Thermal Coated" instead of ceramic coated...
![]() Link Here |
#17 | |
#18 |
I hear ya jkade. I just know that the 1/4" flanges on my current set are iffy at best. They seal with an extra thick gasket. If I can go with 3/8 for a reasonable price I will.
I got a response from Sanderson: "Our BB4 will work, but not the BB8. BB4 is abit shorter." The BB4 are block huggers. I'd like 3/4 length if possible. Here's the BB4 |
#19 |
#20 | |
#21 |
Any more input on this? I'm getting ready to go header shopping
#22 |
#23 |
Active Member
Summit list the patroit as 1/4" flange but the Patroit site list them as 3/8" flange. I have been looking at these but was also worried about the 1/4" flange. If in fact they are 3/8" this is the way I am going. jkade, Maybe you could measure your flange?
Thanks Jack
68 Chevy Long utility bed. Now swb/Bagged Soon to be 468 (Maybe 496) BB/Turbo 400 |
#24 | ||
PATRIOT: ![]() HEADMAN: ![]() |
#25 |
I have Hooker comps on my 69. Chevelle headers, not truck...
