01-08-2011, 04:26 PM | #51 |
Re: What did you pay for your dually ?
01-08-2011, 09:05 PM | #52 |
cab and chassis converted to 4x4 for fire dept. in santaquin utah paid 1800 has 402 bbc
01-08-2011, 09:41 PM | #53 |
1000 c-30 silverado 454/400 90k original miles power everything
01-09-2011, 08:51 AM | #54 |
1988 V30 3+3
Dana 60/70HD TBI 350 4spd/205 $900
1949 Five Window, 1973 Step Side, 2000 Z71 |
01-09-2011, 11:00 AM | #55 |
Will be a year in early February when I drove nearly 200 miles for this 85 C-30 with a '94' flatbed converted to a Knapheide dump bed. This was originally a wrecker until the body shop owner retired,sold the wrecker half and replaced it with the dump bed. My goal was to find a decent 1-ton dump bed for our rural needs. Overall this truck was what I was looking for as a strong foundation with the initial investment of $2700.00. It has taken work on minor things but that's what I enjoy about it...it's old enough even I can work on it!
Plan to continue to maintain it as a "keeper" with occasional "upgrades" knowing what a new one would cost. I figure I have a long way to go before I even make it half the value of a new one! Pic of the day it came home: And a pic from a couple of months ago in a "working mode"... As the budget allows I'll just keep "updating" as I have, and like we all tend to do, but it will always be a 'working' truck...at least that's what I tell the wife. Yet no law saying it can't look as good as it runs. Mark
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." Last edited by RuralRoute C-30; 01-09-2011 at 11:05 AM. |
01-09-2011, 12:08 PM | #56 |
Its the sikkens hot rod black semi gloss paint its suppost to be a 6/8.5 drop but its more like 7/10.5 drop the rear looks like it sits lower than the front but it doesn't. I've sectioned a front crossmember 1.5 inches but when i went to install, a entire can of worms opened up. if you look the rear axle sits in the middle of the frame rail. so a notch had to be made. it's sure a conversation piece
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
01-09-2011, 01:05 PM | #57 | |
-------------------------------------------------------- 1984 CC Dually - 454 - TH400 - Western Hauler Edition Big plans are coming! My build thread HERE |
01-09-2011, 02:25 PM | #58 | |
I tried the x-member section on my 68 before swapping in a Dropmember. What I found was there was no way the post-73 x.member would go 1.5" w/o moving the steering too (steering linkage interfered w/the lower a-arm shaft u-bolt hardware & the x-member lip). The max I could get was 1.125" & still have a minimum .0625" clearance everywhere. I made shims to space it to the 1.125" dimension.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-09-2011 at 02:26 PM. |
01-09-2011, 03:20 PM | #59 |
it is leading to me making tubular a arms, rack and pinion, new steering shaft, now i'm thinkin that a 2 inch z'ed frame would be easier. If its z'ed ill need to shave the bottom of the frame 2 inches so i keep the same clearance, moving the exhaust is easy. then ill still need to borgeson the steering shaft, modify the motormounts ect ect its fun when im getting payed to do the work but its no fun when its for myself with no pay
01-10-2011, 12:51 PM | #60 | |
They are direct bolt ons without an adapter. Truck rides nice. Needs bumpstops as it gets frame on suspension with bigger bumps/potholes, but it's a work in progress.
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
01-10-2011, 01:42 PM | #61 | |
Charlie Daniels w/ a Tq Wrench
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
01-10-2011, 02:12 PM | #62 | |
Home Built '87
That box and matching trailer looks great!!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
01-10-2011, 02:13 PM | #63 |
Home Built '87
I love these reg cab dually's, I missed out on one for sale up here this spring by a few days and have been kicking myself ever since!!
01-10-2011, 03:48 PM | #64 |
I'll split the difference with you... Just looked at the pic and they're Contiental HSR 225/70R19.5s. Thanks man. Jagermester and Rockstar aren't my friends today... and I'm old enough to know better!
01-10-2011, 04:44 PM | #65 |
I meant 70
01-10-2011, 05:00 PM | #66 |
Wow some good deals on duallys on here. I traded a blown 468ci chevy motor (small weiand 177 blower) and an old set of 17" torqe thrust wheels with used tires for mine, but it was in very good condition for the age it was, new motor with only 5000 miles new rear end, new clutch, brakes front suspension ect. you get the picture. Here are some shots the day I drove it home.
"WIDER IS BETTER" (TRUCKS ONLY) |
01-11-2011, 01:01 AM | #67 | |
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
01-11-2011, 12:22 PM | #68 |
My $3250 '88 R30 that I may or may not have paid too much for. Fired right up this morning after sitting out in the snow and cold for several days. TBi may not really be all that for performance but it's nice in cold weather. |
01-11-2011, 12:34 PM | #69 |
You have the exact same wheels as mine, I think that's the first set I've seen other than mine so far.
01-11-2011, 12:41 PM | #70 |
I probably paid too much too, but didn't pay a lot, so I'm cool with it. I paid enough to buy it and that's all that matters I guess! I mean after looking at rust bucket '64 - '65 Suburbans in the $4,500 - $10k range for six months, $3,500 for a running, driving truck with no rust and new wheels and tires seemed just about free!
And every day when I look at my truck, it still makes me smile a big wide smile, so I can't complain!
01-11-2011, 10:45 PM | #71 |
79 single cab dually no motor or trans.. $300
01-12-2011, 12:56 PM | #72 |
I wish I could find a nice dually around washington for under 2500... Not having any luck though.
01-12-2011, 01:04 PM | #73 |
gets board easy.......
i realy like these trucks,
I paid alot for mine, but ill have it forver |
01-12-2011, 03:18 PM | #74 |
Check out the California craigslists. Lots of decent trucks that are going for bargain pricing because they either won't pass smog or the CA reg is way past due and it's too expensive to register them compared to what the truck is worth. Seems like taking one out of state (assuming the laws in WA are reasonable on brinigng trucks in) might be a good deal.
01-12-2011, 03:21 PM | #75 |
First one I found doing a quick search up north... http://sacramento.craigslist.org/cto/2155685856.html
Thread Tools | |
Display Modes | |
