Old 09-30-2011, 11:29 AM   #76
kieth
kieth's Avatar
Re: 66 GMC Fleetside Okie Daily Driver
Before moving the axle back 1.5", which involves moving the air bag mount, adding spacers to the trailing arm mount (or moving the crossmember back, relocating the panhard bar, and moving the shocks and shock mounts, I got under the truck and looked a little today. Had read a lot of stuff on making these old trucks handle and the first step was to install a 2 x 2" solid steel block to lower the truck inexpensively.
So I thought hum, wonder if I could add that block and at the same time move the rear axle back. Drew up a little 2x2 x 9" block that we could bolt from the bottom of the trailing arm in the stock location, drill and tap 2 holes in the stock location then drill and tap 2 new holes in the top of the bar 1.5" back then add a strap to the top of the rear end to replace the U bolt and voila the axle is back without major work, the truck is lowered, the trailing arms have more clearance so the truck can go lower, it does not cost much, and it is easy to do.......what do you folks think ? Kieth
ps----the panhard rod has to be relocated at the same time.
kieth is offline   Reply With Quote
Old 10-27-2011, 09:59 AM   #77
kieth
kieth's Avatar
word of warning for all those installing fuel injected engines, when buying the fuel pump and the fuel tank, get the tank with the fuel pump in the tank, it will save you a lot of grief.......................JMO
ps 4 electric fuel pumps burned up--------------learn from my mistakes. Kieth
Old 10-27-2011, 10:08 AM   #78
kieth
kieth's Avatar
Lessons learned in this build:
1. Body work is Chinese water torture
2. have a donor vehicle and keep it around you never know when you will need something else off of it.
3. replace all front end parts with new stuff, it is not that expensive including rotors, bearings, disc brake calipers, brake lines, power steering lines, hoses, belts.......
4. Make sure you check the clearance of the fenders with the wheels and tires you purchase along with the lug bolt pattern.
5. Listen to the pros on which air bags to use where.......
6. If going with really wide rear wheels and tires move the whole crossmember & suspension back 1.5"
7. Use original body parts if possible they are lots better than the new stuff
8. If you are going to alter the stance of your truck start with -2.5" front spindles-----then go from there.....
9. It is cheaper to buy a truck some one has already done all the work on but not nearly as satisfying...........
10. If you install a fuel injected engine use all metal lines and install the fuel pump in the tank.....
11. When moving the crossmember back be sure and drill out the rivets for the Trailing arm bushings. Even if you are not going to lower your truck now you may need to flip these brackets in the future and drilling the rivets and replacing with good bolts will allow that mod to be made without any problems........Remember it is a lot easier to modify the suspension and frame with the body off and it will look better later also.
Old 11-10-2011, 12:46 PM   #79
kieth
kieth's Avatar
Almost done with the green gmc, still tweaking on the rear suspension, here is a new shot of the stance she now has....
Old 11-10-2011, 01:05 PM   #80
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Keith, tell me what size tires your running on the back, 17" rims right?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-10-2011, 04:39 PM   #81
allaboutchevelles
allaboutchevelles's Avatar
Kieth, That GMC is looking good to me. I love that stance. If mine sits like that when im done ill be real happy. Thats a good looking truck!!
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 11-10-2011, 06:53 PM   #82
kieth
kieth's Avatar
265/70/17 Michelins and they barely fit very little clearance on the inside or the outside....rims are 9" wide.....
Fronts are 255 65 r 17 michelins,,,9" wide,I may change them to 245/60/17 and then air bag the front.....to get it a little lower and have more room to drop the front and clear the front fenderwell lip....
Have not notched the rear yet but will just to gain some clearance for the rear axle, it rides like a cadilac now....
Rear: air bags 8" firestone (will be changing to 9000 series)
2" spacer blocks
stock shocks---stock location--will be changing soon after doing frame notch.
Front: stock 6 cylinder springs
2.5" McGough drop spindles
stock shocks
will be changing tire size and then bagging the front soon...
I have a new long panhard rod on order will install it soon.
Thnks for the compliment, it does look different from when I started...
Name:  Exterior head on front.jpg
Old 11-12-2011, 09:57 AM   #83
kieth
kieth's Avatar
Added a tonneau cover:
picture show trial fitting:
Just a trial fit, not final, not all parts installed including the rear corners...
Old 11-12-2011, 04:42 PM   #84
McMurphy
McMurphy's Avatar
Nice build all around.
I really liked your Lessons Learned list too... I am going to start ordering parts for repair and mods soon and am nervous about making bad purchases.
Where I live taking it back to the store may not be an option, and waiting on the mail man can be painful to the wallet and the watch....
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 11-13-2011, 01:04 PM   #85
kieth
kieth's Avatar
Thanks for your compliments, but I have messed up quite a few times but maybe changing the truck after you get it driveable is what this process is all about. When my gmc is down for a few days for mods I really miss it.....I really like driving it every day.....it makes a dull drive into a lot of fun.
I am 61 and it has been a few years since young girls have looked at me all smiles and asked me to roll my window down and they say Oh, we just love your truck !! Kind of makes an old mans day.......!!!!!
Funnier still is the lack of knowledge which comes from the young guys, they like the truck, but do not know enough about them to say nice 66 instead they say nice classic ??
Oh well not enough 2 parent familys around to educate their sons.....
Going out to finish the tonneau install......good way to spend a nice Sunday morning. Kieth
Old 11-13-2011, 05:21 PM   #86
McMurphy
McMurphy's Avatar
Kieth I am following up close behind ya, I rolled 48 on my odometer this year too.
Da'Vinci said "you never finish a piece of art, you just abandon it." I kind of think of Classic Cars in the same light. They never truely are finished to the point where you look at them and say "I did everything I wanted to" ..... or at least that holds true for me so far. LOL
All you OK guys make me wish we were still stationed at Ft Sill. Would be great to meet up with all of you from time to time for coffee or beers and brain storming these rigs.
By the way, my Tempest came from Tulsa.
Was a long drive up there to look at it, but went back the next weekend and paid cash for it.
This photo is outside our house in Lawton.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 11-14-2011, 11:31 AM   #87
jason65
Registerd User
jason65's Avatar
Good looking truck Kieth.
jason65 is offline   Reply With Quote
Old 11-14-2011, 03:33 PM   #88
kieth
kieth's Avatar
Thanks Jason, yes mcMurphy
Ft Sill is still around but it got a little warm there this summer, there is a salvage here in tulsa that specializes in old 60 to 64 tempest parts........he only sells on the internet you cannot walk in and buy anything........thats a good looking car do you still have it ??
Old 09-03-2013, 01:19 PM   #89
Ta2Don
Ta2Don's Avatar
Thanks for the info... it worked, caught Grizz on the train after work...
Have a great week, hope to meet you in person at Clem's...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Thread Tools
Display Modes
