#201 |
![]() Join Date: Jul 2010
Re: No Limit's "K-10"
This is how I do bodywork. The rail tops of the bed are really rough, So, I just cut them off, and formed these from 18 ga. They are a little different shape than the stockers, but you'll get the idea
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! Last edited by robnolimit; 01-16-2012 at 04:16 PM. |
#202 |
Here's a shot of the new top fitted, then welded and smoothed. I really don't like body work, so I have to do it a little at a time. Second pict shows some more paint stripped, and I metal finish it as I go.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! Last edited by robnolimit; 01-16-2012 at 04:19 PM. |
#203 |
A shot of the drivers side, and some overall shots. The recess area is for the hard tonue cover (I'm sure I spelled that wrong) to sit in.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! Last edited by robnolimit; 01-16-2012 at 04:21 PM. |
#204 |
GEARHEAD
Welding the bedsides to the cab too? Not much left of the original sheetmetal on this project. Any target weight in mind?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#205 |
awesome!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#206 |
Maybe you should use this to keep the weight down.
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
#207 |
Junk Yartist
It does look like they are pushed forward, doesn't it.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#208 |
6>8 Plugless........
![]() Join Date: Sep 2007
Is it just me or does the bed look shorter than a standard 6' bed too? Truck is looking sweet either way Rob. Great work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#209 |
Still Learning
Awesome met fab skills here. don't think it will take very much filler when you do the body work. Keep the pics coming.
#210 |
Nope, not a whole lot left of the OG longhorn. Yes, I'm going to fit the side to the cab, Blazer style. That saves the wieght of the front panel. My target is 28oo lbs, - but 3000 is more likely for an all steel body. OK, it's a little shorter than a stocker. I trimmed the longbed side down to the factory length for a SB, but it's moved forward 5". I'm working hard to kep the proportions right. It will either look really cool, or a bit goofy. And Hey, don't be knockin' the evercoat, thats some good stuff right there.
GoodGuys 2012 Pro-Truck Champion ![]() 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion ![]() 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion ![]() Proud to put our products up against all others! |
#211 |
I got your old right here buddy! lol 70 3/8 if that is the length of that bed side? but with your wheel base I guess that would be about right. Looks really good. Where are you putting your fuel cell? I was going behind axle but am having second thoughts I can keep it really low there gravity you know but the weight of the can can play havoc that far back. Nice work on keeping the bars all under the fake bed cover that makes it look really clean.
#212 |
67cheby
![]() Join Date: Sep 2008
man that bed and and rear frame are looking AMAZING ! love how you recessed it for the bedcover !
#213 |
Still plays with trucks
About a year ago yes but I changed careers to something more stable and no longer have access to the software needed.
I know there is a thread where a member analyzes the different C-notch designs with finite element software. You might be able to work something out with him professionally to do it. I'll see if I can find that tread again.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#214 |
Rob first off nice build! secondly I have a question about your spindles. I've been around dirt racing and the circle track world for the better part of 8 years. I was thinking on all the fabricated spindles,the left was different from the right as far as the height and steering arm location. Am I missing something? I will never claim to know ever thing but I have looked into the fabricated spindles before. I may have missed something. Any insight would be appreciated! Hope to see you at RTTC again this year!
GT |
#215 |
FRor the most part your right. But, Howe racing will make them any way you want. I had lengthy discussions with thier spindle tech, who was well versed in road racing. After a few calls, we decided on some specs, and they built them. Very helpfull people. Trent got his there at about the same time. I think they were stunned that two guys, 2500 miles apart, were going to try the same thing, and then when I asked him, is the other set for a guy named Trent, he was set back a bit. Small world. Yes, I'll be at RTTC, with something, silver, green, grey or yellow.
#216 |
Thanks Rob! I appreciate the info. Ive been looking into building a RR/AX 88-98 truck and had the same ideas you and trent have. Being around the dirt cars(modifieds and late models) there is a lot of good susepension bits out there that can cross into our world. Thanks again!
GT |
#217 |
sub this one.
The craftsmanship is just incredible!!! keep up the good work, and also keep the updates coming. |
#218 |
Updates
#219 |
More Updates
#220 |
And More
#221 |
Dumb question... and just out of curiosity:
I was wondering why you made the sheetmetal on the floor that way? I have never seen it done that way. Didn't know if it was an old school technique that I never got to be a part of, or if it was beneficial in some other way?
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#222 |
The last updates
#223 |
67cheby
Holy smokes
#224 |
Wow!!!!!
Posted via Mobile Device |
#225 |
C-10 Club Member
Great work......
![]() You can't copy I already have "the" yellow truck ![]() ![]()
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
Thread Tools | |
Display Modes | |
