Old 05-02-2010, 06:32 PM   #1
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Front coil spring removal from a 68 3/4 ton gmc
I pulled some leaves from the rear of my truck and got about a 3.5" drop, so now I need to get the front down. I read the FAQ about spring removal but I still can't get the ball joints to let go. I backed the nuts off about 4-5 turns on the lower ball joints then I gave the spindles good whacks and nothing happens. First I used a 24 ounce framing hammer, then I used a 3 lb sledge and still nothing. Is there something I'm missing here? Are the 3/4 ton different than the 1/2 ton? I would rather not use a pickle fork as the ball joints are nice and tight and I don't want to change them. Any info would be greatly appreciated.
PS: I'm on a tight schedule since it is entered in a carshow on saturday.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-02-2010, 06:34 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Front coil spring removal from a 68 3/4 ton gmc
Keep hitting them, eventually they will "pop"
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-02-2010, 06:41 PM   #3
Piece of Work
Cultural Infidel
Piece of Work's Avatar
forget the ball joint method. remove the u-bolts from the a-arm. your springs will come out easily.
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 05-02-2010, 06:44 PM   #4
Leviticus
Shake and Bake!
Leviticus's Avatar
I pulled the top ball joint instead of the lower on mine when I did my coils. Just backed the nut off and one good bump with a big rubber mallet and whamo, it popped loose.
The pressure of the spring and the weight of the spindle may have helped with it.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 05-02-2010, 06:48 PM   #5
Jacfourteen
I considered this, but when I removed the nuts from the 1st U-bolt it wouldn't come out of the frame, but I guess that when I pulled the other nuts and lowered the jack they would probably come out right? Guess I will beat on them some more and if that doesn't work I'll pull some U-bolts. Thanks for the quick responses.
Old 05-02-2010, 06:48 PM   #6
Jacfourteen
Good Idea, I'll give it a try.
Old 05-02-2010, 09:52 PM   #7
Tkmadone
If you have it jacked up under the lower arm then whacking the ball joint won't work. The spring needs to be pushing the lower A arm down and it has to have room to move when you whack it. Jack it up and use jack stands under the crossmember or on the frame behind the front wheel well.
Tkmadone is offline   Reply With Quote
Old 05-03-2010, 02:01 AM   #8
Jacfourteen
Yeah I had the stands on the crossmember, but they wouldn't budge.
Thanks for all the ideas, I ended up loosening up the uppers and they popped right off. They were a little more of a pain because then I had to fight with the brake lines but I got them out and chopped 1.5 coils off. That got me down about 2.5" in the front and the leaves I pulled got me about 3.5" in the rear. I may go a little lower, but I think for now I will drive it and see how I like it. Now I just need to bolt it all back together. Once again thanks for the help, once again the board saved my butt .
Old 05-03-2010, 04:35 AM   #9
harry
harry's Avatar
can you post some before and after pics of your lowering,sounds like an inexpensive way of doin it,might do my 3/4 that way as well
harry is offline   Reply With Quote
Old 05-03-2010, 04:53 AM   #10
Sublvr72
Sublvr72's Avatar
use a pickle fork and they will come off.
Sublvr72 is offline   Reply With Quote
Old 05-03-2010, 12:59 PM   #11
Jacfourteen
I'll get some pics up later today. Do you have coils or leaves in the rear?
Old 05-03-2010, 09:25 PM   #12
harry
harry's Avatar
leaf springs in the rear of my c20
Old 05-04-2010, 12:40 AM   #13
Jacfourteen
I got it all buttoned up this afternoon. I got a few crappy phone pics as it was getting dark outside. The 1st one is what it looks like now, the 2nd one is jacked up to the original height (I didn't take a before but I did measure it)
Sorry about the bad quality of the 2nd pic, it looked good on my phone then when I downloaded it it was all blurry. I'll get some better pics soon.
Thread Tools
Display Modes
