Old 10-27-2004, 12:23 AM   #1
camelot
WTB TH350 K case
I am looking for a K case for my cracked TH350. I don't need the insides, just the case. I'm in California, so that would be best, but if you are willing to ship, I am OK with that too.
Thank you,
Camelot
www.toyotagirl.com
1985 Chevy 4Runner
1972 GMC 4WD
camelot is offline   Reply With Quote
Old 10-27-2004, 08:06 AM   #2
GMC AMI
GMC AMI's Avatar
Smile Case?
I have one Camelot if you can not find a closer one. From a 1971 GMC 4x4,thanks, Mike
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 10-27-2004, 11:18 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I bought one as a core from Olympic 4x4 in Snohomish, WA. They charged the same price for a K case as a standard case. http://www.oly4x4.com/
You might check with your local transmission shops or 4x4 shops to see if they have one. I might have just got lucky. The transmission shop wanted $450 just for a case! Personally, I think he was smokin' something.
Also, check out the message boards on Pirate4x4.com and ColoradoK5.com
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-27-2004, 11:46 AM   #4
landon4421
Life is Good !
landon4421's Avatar
Camelot, did you try Santa Clara truck wreckers yet Up there that would be your best bet ! Good Luck man
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 10-27-2004, 02:50 PM   #5
Litdave
What is a "K case"? I have seen this mentioned a few times for both TH350's and 700r4 transmissions.
Is it just a case out of a 4WD or is it a heavier duty case that came in some 2WD's?
Thanks.
71 Factory SWB 4x4 Project 383/350/205
69 LWB 2wd CST Daily Driver ZZ4/700r4/3.73
72 SWB Future Hot Rod
Litdave is offline   Reply With Quote
Old 10-27-2004, 03:43 PM   #6
bouncytruck
SKINNY TIRES RULE!
"K" case is a 4wd case. It has a huge "K" cast into the top side of the bell housing. I have heard some say they are thicker than the standard case, but others say they are the same. They do have a cast aluminum flywheel/dust cover.
bouncytruck 1972 K5
Old 10-31-2004, 02:49 PM   #7
camelot
Thanx for the places to look for a case. I'm not a fan of SC truck - but I'll give them a call. http://www.oly4x4.com/ didn't have anything available - no TH350's at all right now.
Litdave - I guess the case is heavy duty. The key, I have been told, is in the dust cover. It holds everything in place to withstand more tweaking when offroad.
Pirates board has a cracked one avaialble - maybe they aren't so strong afterall....
Camelot
www.toyotagirl.com
1985 Chevy 4Runner
1972 GMC 4WD
