Brakes
Has anyone used a 1988 master cylinder and booster on a 67-72 chevy truck also the steering box will it bolt up?
Got Light Emitting Diode?
i am pretty sure it is only 69-87 p/s boxes that work. for a 2wd if thats what you are talking about. just look at the difference. does it still bolt on the outside of the frame. 4 bolt holes. the rag joint the same? as far as the master and booster, i cant help there
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Watch out for your cornhole !
![]() Join Date: Jun 2003
88 and newer steering boxes bolt inside the frame, rather than outside like 87 and older trucks do.
its all about the +6 inches
The 67/early 68 frame needs light mods to use a later box. There is a dimple that needs placed on the frame rail.
The gear box from 73 - about 80 will work fine. The later ones will work, but the hose connections are o-ring style, and metric. The master cylinder, i wouldn't touch it myself if you have a 67 - 70...(drum/drum verses disc/drum) And honestly, onless I had swapped the whole 73 - 87 brake system to the older truck, I still wouldn't do it. |
Here's a pic...
The little plastic deal on the booster, at the end of the (steel braided) hose. |
hey andy wrong brake thread
