10-28-2004, 09:48 AM | #1 |
Brake hiss...
Help...
I'm having a little brake trouble on my '87 burb. When I depress the brake pedal, I hear a hiss that sounds like a small vacuum line hissing air. This persists about half the pedal travel and I have no brake power. Then on the bottom half of the travel, the hiss stops (mostly) and I get brakes. There is a place along the travel that I can hold the pedal at and get a constant hiss and no brakes at all. What is this? -Kris |
10-28-2004, 11:45 AM | #2 |
Who's in CHARGE??????????
i would bet its your brake booster
Send a card to a soldier in Iraq My Music PlayList Large Marge Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE |
10-28-2004, 05:37 PM | #3 |
Magnificent bastard
It is your brake booster. I had the exact same problem, put in another one with a 12-month warranty, and 13 months later it did it again @#$%*^%$. I was so excited... If its the first time you've changed it, you have my sympathies.
Also, if your master cylinder is leaking into the booster, that will kill it.
1977 Big Block Burb Last edited by Bad Karma; 10-28-2004 at 05:41 PM. |
10-29-2004, 08:40 AM | #4 |
Yes, its the booster, or the little plastic piece that the hose connects too.....pretty common for the to crack with heat/age and they arent very expensive....check that and the hose for leaks first (it may be dry-rotted).
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
10-29-2004, 09:21 AM | #5 |
Thanks...
Thanks for the info y'all. Is this piece inside or outside the firewall... I've never replaced one, but I have replaced my master cylender 3 times
-K |
10-29-2004, 10:58 AM | #6 |
Magnificent bastard
The plastic piece is a check valve that is located on the booster in the engine compartment. It has a hose that runs to a vacuum source (mine goes to the carb).
1977 Big Block Burb |
11-01-2004, 09:16 AM | #7 |
well.................did you fix it?
11-01-2004, 11:36 AM | #8 |
Not yet... I'm a big Halloween guy and was working some Haunted Houses. I'll take a look this coming weekend and keep ya posted.
Thanks, -Kris |
