RPM at 70, hmmmmm
http://www.thirdgen.org/techbb2/show...hreadid=114139
check out the 9th reply by Don_89Iroc interesting, |
its all about the +6 inches
That MIGHT work with a certian size tire...but you'd do so much math to figure out the tire size you need, you could have already pulled the cover, counted the teeth, and filled it back up.
someday
![]() Join Date: Dec 2001
i have used this site it seems pretty close there are others i have seen too. http://home.off-road.com/~wsjc/calculators.html NO MATH required
Click Here to search ebay for all 67-72 parts My 72 CST blazer build 72 CST Blazer 4x4 67 2wd swb ( project onion crate ) 86 4x4 lwb plow truck 40 x 60 foot barn to work on all this stuff |
personally...I just count the teeth. You know the oil has been there since the '80's anyways.
Someone is smoking some SERIOUS crack!
Take my '68 for example. At 70mph, my RPMs are about 3300. Does that mean that I have 3.07s or something? Wow, someone should tell my 4.57s that they are really 3.07s! Oh wait, it's a stick, so it doesn't have a "Drive". How about my 'burb? It's got "Drive". At 70 my rpms are about 2800. Does that mean that in "Drive" my rear gears magically transform from the 3.73 ratio to some magical ratio that's less than a 3.07? For that silly little trick to work, you would have to have a tire size of 23.5" -24". Unless your tire height is close to that, it just aint gonna happen.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
well on my 67 long bed at 70 mph im at 3700 rpm, and thats with 27 inch tires...oh yea i have 3:73 gears...hmmmm works in my case
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
14.1 @ 96MPH
that trick only works on a certain number of tire sizes and tranny combos - autos without lockup converters will run RPMs similar to a stick (or probably a lockup auto) with the next ratio numerically higher ratio. without factoring that in, my RPMs are more like a 4.11's (and I've done the real math, it's not hard at all! lol) but i've got 3.73s.
Trust me, for me, I can do the math a LOT faster than I could pull a cover and count teeth. Lucky for me I know my truck's exact history. ![]()
Project1970 - LS1 Swap Complete! ![]() |
If you're running HEI and stock original Tach's, your RPMs will probably be off several hundred rpm at 70mph so don't get hung up on it.
Then it is time for a new tach.
HEI shouldn't have any effect on the tach at all. |
![]() Join Date: Jan 2001
Location: Katy, TX...but the love of my life resides in Dublin,OH.
Autometer says that their tach might be + or - 100 rpms... My speedo doesn't read correctly so I guess I can't find out I have a 4.11 rear end...for the record... I'm turning 3300 to 3400 with 29" tires...
dobster- {rpm x tire diameter} divided by {mph x 336} = gear ratio
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint ______________________________ |
