Old 11-03-2004, 12:10 PM   #1
sdmahr
sdmahr's Avatar
Shock Removal
OK, I bought 4 new shocks and got under "the beast". I clearly see a bolt and nut to remove the lower mounting of the front shock. On top, it appears a little different. How does the upper part of the shock get removed? It appears to be a headed pin.....I don't see anything to "remove" to pull the shock off of the pin.
Share some experience with me please !
sdmahr is offline   Reply With Quote
Old 11-03-2004, 12:33 PM   #2
JimKshortstep4x4
Smile
There should be a nut on the inside of the frame that you can remove. Your new shocks should come with studs to replace the pin.
Jim
Old 11-03-2004, 01:26 PM   #3
sdmahr
sdmahr's Avatar
The new shocks didn't come with anything other than the shock. Do I need to find new pins for the top of the new shocks?
Old 11-03-2004, 02:59 PM   #4
JimKshortstep4x4
Smile
You will need pins. I believe that I have a couple of extra ones, (new). If I do I will send you them for $2 including shipping. PM me if interested.
Jim
Old 11-03-2004, 10:13 PM   #5
sdmahr
sdmahr's Avatar
Well, I feel pretty stupid. There was a plastic bag with the pins/bolts/washers in each shock box. They were stuck in the end of the box I didn't open and were being held there by the adhesive used to close the ends of the box. After taking the shock out the box still felt heavy on the end I didn't open.
Thanks for all your help.
Scott
Old 11-03-2004, 10:57 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Tighten the crap out of them. Use a big breaker bar to cinch them down big time.
Lots of times, they get loose and wallow out the holes in the frame, causing a lot of damage.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-04-2004, 07:24 AM   #7
JimKshortstep4x4
Smile
Sounds like you are all set! I want to echo what Tx firefighter mentioned as that is good advice. The large inside nut should be tight!
Jim
