10-26-2004, 02:14 PM | #1 |
Need Fan Size
What is the size of the steel 5 or 6 blade fans with a fan clutch? 17 or 18 inch?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
10-26-2004, 03:25 PM | #2 |
Left Foot Functioning
Skokie,
For my new GM shroud (for a C10 SB V8 with A/C), the opening is just over 19". I talked to the folks at Flex-a-Lite recently, who advised that the fan should be approximately 1" less in diameter than the shroud opening, and they suggested their 18" (#5718 standard rotation, #5918 reverse rotation) for my application. They also recommended their #5657 HD Thermal Fan Clutch for my reverse rotation application (serpentine pulleys). Not sure if that also works for standard rotation, but it looks like it does. Here are their web pages for fans and clutches. I ordered the parts from Summit Racing. SSOW
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
10-26-2004, 04:07 PM | #3 |
I checked summit and its looking like its going to be the FLX-5718 for the fan and FLX-5534 for the fan clutch. Not sure about the fan clutch though since there are 4-5 to choose from.
10-26-2004, 04:44 PM | #4 |
I went with the HD 5600 series clutch based on recommendations from my vendors, since I'll be running A/C (Old Air system).
The 5500 series does not have the bi-metal spring to react better to temp changes as discussed in the other thread. If you're not seeing heavy loads or high heat, you'll probably be fine without the HD. SSOW
10-26-2004, 05:20 PM | #5 | |
That and I am not running a ac. Thanks again ..
11-08-2004, 04:28 PM | #6 |
Fan
Hey SKOKIE
Did you get your clutch fan set up yet???
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
11-08-2004, 05:11 PM | #7 |
I got the part numbers from summit. Looks like its going to end up as a christmas present. Im getting a 18 inch fan and a thermanl clutch. Looking forward to quieting the truck up a little. That flex fan has got to go.
11-09-2004, 03:19 AM | #8 |
When you get it in let me know how it works out THANK YOU
Gary
11-09-2004, 12:24 PM | #9 |
How much is that going to cost?
--------------------------------- 72 C10 SWB 350 Work in progress 98 HD Fatboy 09 HD Heritage Softail 05 Honda Element |
11-09-2004, 12:54 PM | #10 |
The fan is 33.39 and the clutch is 39.95 so around 80 for both.
