What kind of choke?
What kind of choke was on a 68 sbc with a quadrajet? Also tranny is automatic if that matters.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
The type that has a choke coil mounted on the manifold.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#3 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Was that a manual choke?
The manual choke had a cable in the cab you could pull in and out. I think it was on the guage cluster. The divorced kind on the manifold were mechanical. The heat would do the work by expanding the coil and then lifted the choke up.
69 GMC 1 Ton Longhorn 37 Chevy Coupe |
Would the divorced choke lower the rpms of the truck as the engine got hotter? Was that adjustable?
Ttt
Its Magically Delicious
i believe you can adjust the divorced chokes by bending the choke coil rod accordingly .. how low are the rpms dropping ??
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
You will still need to blip the throttle to release the fast idle once the truck has warmed up some.
Thanks guys. Appreciate the info. I dont have the quadrajet on the truck yet Its in need of a rebuild first.
