62 Suspension conversion to newer 71 and up disk
Can a newer suspension bolt up to the old torshion bar style 60-62 truck front end... I am asking because I have a 1962 and would like to go disk and Airbag with out spending 900 bucks on a aftermarket disk kit , and still not be able to go with airbags...
![]() Thanks Chris |
born to drive a CHEVY
disc
should bolt right up to old holes
you can get drop spindles for around 200.00 and then use junkyard rotors and callipers.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
Up to what year will work?
Chris |
buy the spindles for your year truck,then use the brake parts from a 1973-87.ask the spindle maker what fits.
C10 now is a GMC
If you're going to replace the front suspension, make sure you pull it out as a whole unit, cause the torsion bars are under alot of tension.
![]() ![]() I plan on doing this swap eventually too, after I swap the 235 I6/3 speed for a 350/350 setup. ![]() Or if you're wanting to make your truck a swb, find a donor swb '63-72 GM truck frame, or even better, a '71-72 swb chassis, and it wil have 5 lugs with disc brakes. ![]() David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
