Old 06-25-2002, 08:48 PM   #1
jhow66
jhow66's Avatar
Temp gauge
After doing a 1 year back search with no luck need help. Here's problem--(new gauge, new sender,wire check to ing. and sender-OK)-after starting engine gauge will slowing go to full scale before engine is warm. ( wire not grounded because it will stay put when engine is cold when you turn on switch--only starts to move when engine is running.) 71 manual says sender will not read correct if coolent is not protected to 0* or below--anyone every hear of this? --ours is.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-26-2002, 03:59 AM   #2
WORNBRAKES
Wish I could help. Someone should be able to though. Welcome to the board.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 06-26-2002, 04:00 AM   #3
WORNBRAKES
Oh I forgot. NICE TRUCK!
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-26-2002, 08:50 AM   #4
JimKshortstep4x4
Smile
This is what I would do because I suspect the sending unit. Obtain the ohm reading specification for the sending unit, pull the unit, heat it to 212 degrees and measure the ohm reading you get. Compare the actual vs specified values. (They should be close). The gauge moves in relation to the signal that the sending unit sends to it and it works by increasing the ground.
If the unit is putting out the right value, then the gauge is at fault.
If someone doe not post the values, I will try to get them for you.
Jim
PS: Nice truck!
Old 06-26-2002, 06:56 PM   #5
jhow66
jhow66's Avatar
gauge
Thanks guys for the replies. 4X4 I have the values--I got them from my parts man as I drove down to work on the truck (not mine). Will try the ohm test tomorrow. Looked at another new one and it is the same as we have. Today I hooked up another gauge (he had a extra dash cluster) out side of car and used the sender in engine--did the same thing. This leads me to think that you are right about the sender. If you come up with anything else let me know. Thanks again.
Howard
71 Cheyenne SB
PS PB AC 400 Trubo 3.07 POSI
502 HO crate motor (450HP--550FP TQ
My other "TOY"--One owner 56 Chevy
Old 06-27-2002, 06:16 PM   #6
jhow66
jhow66's Avatar
gauge
Hey 4X4 you were right!--bad "new" sender. Checked extra gauge on my truck--worked. So installed another new one --works great . Thanks for the help.
