Old 11-13-2004, 04:26 PM   #1
Chevyguy111786
Lift a 2wd
I saw a suspension lift kit for a 2wd on ebay. it had the rear blocks and then it looked like front blocks for the coils....this doesn't seem real safe to me. is this somethin that they made...it was an actual kit, not homemade. i'm looking to get about 2 inches of lift. should i go suspension or body? and who sells good kits for a 78 lwb? 1/2 ton. could i just put 3/4 ton springs on? and get some lift?
Chevyguy111786 is offline   Reply With Quote
Old 11-13-2004, 04:34 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Here are new HD moog coil springs installed in the front. I still have to fix the rear very sagging springs. Tires are 235/75-15 on 15x7.5 rims
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 11-13-2004, 05:51 PM   #3
Chevyguy111786
would these work on a 78? Ebay Link
Old 11-13-2004, 05:53 PM   #4
EricS76
EricS76's Avatar
I put a set of trailmaster add-a-leafs on yesterday. Got just shy of 3 inches of lift and they firmed up the rear to about were I wanted it. I'd think the best way to raise the front would be a set of raised spindles, but I haven't ever seen any. Has anybody else?
‘66 Chevy C-10, long bed fleetside, 350, 3 on the tree, 4-7 drop.
'77 chevy C-10 Custom Deluxe, 350, SM465 4 speed, flatbed.
'80 jeep CJ-5.
‘14 Chevy 1500 Z71…
EricS76 is offline   Reply With Quote
Old 11-13-2004, 06:11 PM   #5
Chevyguy111786
i haven't seen any either, they are all for newer vehicle's anyone know of a year that will work? also have seen the torsion bar keys or whatever they're called that raise it 2-3 inches....but only see them for 88 and up...anyone?
Old 11-13-2004, 08:29 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
That ebay link is for an 88-98 is that what you have?
http://www.aitsafe.com/cf/add.cfm?us...n.com&units=75
Rough country makes a nice complete kit including shocks for $295
Fabtech motorsports sells a 4" long travel that comes with spindles/control arms and shocks, but its like $1400
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-13-2004, 08:50 PM   #7
cochino12
It followed me home?
cochino12's Avatar
superlift has some stuff
link
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-13-2004, 09:15 PM   #8
Chevyguy111786
thanks cochino...that's just what i needed
Old 11-13-2004, 11:43 PM   #9
Prerunner1982
Prerunner1982's Avatar
Spindles were made by AIM at one point, but due to low demand they no longer produce them. Coil spacers are ok, but like lift coils may cause odd tire wear and alignment problems. They do make ball joint spacers to attempt to correct this problem. A 3/4" coil spacer will provide about 2" lift. For a cheap lift to run larger tires a body lift isnt a bad deal, though i hope your bed is in good shape and i hope you dont plan on hauling heavy loads, i have seen beds bend in the middle. Spindles would be the best lift and i have heard you can machine the control arms to fit 88-98 lift spindles.
btw...what size tires are you wanting to run? i run 32x11.50x15 with HD front coils and stock rear.. also if you are wanting larger tires, you can run 'glass fenders on the front and fit 35" tires with no lift. They make fiberglass bedsides for shortbeds, but havent found any for longbeds... yet..
Prerunner1982 is offline   Reply With Quote
