sway bar help
ok, this should be an easy thing to put together but im lost. I have a 1 1/16 sway bar off a 69 2wd half ton. I ordered the lowered brackets from early classic and poly bushings along with the other parts i needed. It was all fine but the bar sticks out of the bushing 3-4 inches where it is mounted on the control arm and rubs my air bag. i have turned the bar and brackets different ways with no solution. WTF am i missing? i knocked the rivets out of the crossmember and have studied the FAQ section with the write up on this swap.
Sounds like your brackets on the frame are mounted to far to the rear? Just did this mod, and had no problems.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
If you trimmed the ends of the bar, would it work then?
I have no idea of what it would take to trim a swaybar though. I think they are made out of the same steel as the door hinges of Hell are.
Correct original sway bar should extend no more then an inch beyond the lower A frame mounting bkt. Make sure you have the frame brackets in the correct place and are mounted correctly---. They usually are a pretty easy install--bolt up. If still an issue, post a picture so we can see what you are dealing with and can advise---be sure to show which mounting holes you are using on the frame. Huck
the truck has a 77 front crossmember under it and a 68 frame, would the newer front end be more forward maybe?
My truck has the 1 1/16 bar on it if you want to take a look at the factory install. I won't be home this weekend but the truck will if that helps. If you decide that you need to cut the bar I've got the stuff to make it a snap. I haven't forgotten about the front end alignment and scales for your truck, some stuff came up and got real busy. BTW Do you have the alignment specs that we would need? Like I said the truck will be out in the driveway if you want to scope it out. Take care, Bart
72 Cheyenne Super waiting on 4/6 drop,BB and 700r4 |
ttt
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
One last pic for lost.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
thanks jzero
Trim an inch off the ends and you should be good to go.
I have no idea why your bar hangs out of the back of the brackets like that. It's obviously installed correctly.
Wo baby----not liking what I see here. Will take a picture of a stock setup and get back with you--- don't cut that bar just yet~~~~!
Next project: 1970 K10
It looks to me that as the frame is lowered (moving the front of the bar down) and the lower control arm becomes closer to the frame (control arm moves "up", raising the rear of the bar), the rear of the sway bar would rotate up, closing the distance between the mounting point on the arm and the end of the bar. In other words, as the bar rotates up, the end of it naturally will swing farther back until it reached a level point, then move away from it again.
Clear as mud? ![]() Now, start pulling down on the control arm and the sway bar should start to pull through the bushing closer to a normal position as it rotates down. I'm thinking that shortning the sway bar a little should do the trick, so long as there is not too much trimed off so that it could slip out if the front suspension reached full extension. Just my $.02
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 11-15-2004 at 10:30 AM. |
i had the truck on jack stands(not in these pics) and the a arms just hanging and it still was long.
Flake Daddy
the front of mine is bagged...and as I recall...mine was rubbing on the bag as well....I simply trimmed off the back edges a little at a time till I found what I needed...
rigo
1968 SWB Fleet Daily Driver 350/TH400 shaved driprail,emblems,tailgate,air ride suspension 1964 Pontiac Catalina 2dr. hardtop shaved everything, air ride suspension 1998 Range Rover 1960 El Camino....in the works..... |
#15 |
Looks like the center frame brackets are mounted in the wrong holes. The rear hole in the frame brackets need to be in the hole that front lower crossmember rivet was in.
edit: I can't tell for sure if the brackets are mounted in the correct location, all that silver has my eyes playing tricks. But it's sure nice to look at. ![]()
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. Last edited by 71Chev; 11-15-2004 at 02:30 PM. |
#16 | |
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#17 | |
I'm pretty sure they are. I pulled out some pics of mine and they are in the same spot. I'm kinda puzzled as to why is would be too long, ![]()
#18 |
It may be my eyesight or just the prespective ( my bar is 1ΒΌ") but that sway bar looks like the arms are longer than my bars. Mine measure 14 1/8" from the front of the bar to the end of the arm, check the measurement on yours.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
#19 |
My frame mounting brackets drop about 2 3/4" in the rear which look like it is more then yours. They mount---rear hole in the front crossmember hole on frame and the front bracket hole aligns in the first circular hole behind the ovel one. My sway bar extends maybe 3/4" beyond the lower A frame mounting bushing.
