6 lug to 5 lug?
How hard is it to change a 6 lug truck to 5 lug?
For the front, the easiest way is to buy a disc brake conversion spindle from one of the board vendors, and use your existing suspension and steering components. Another option is to swap the complete front saddle from a disc brake model('71-'87 will practically bolt in), but if you want to change only the required parts, using a donor truck, here is what you will need for the front:
spindles & backing plates calipers brake hoses steel brake lines Proportioning valve Master cylinder upper and lower ball joints tie rods center link pitman arm For the rear- You have a few choices. If you have the late '70 wide rearend (someone help me with the measurements), you will need 5 lug axles and drums from a '71-72 rearend. If you have the shorter 6 lug rear, you will need to either swap the complete rearend, OR use a 3/4" spacer on each side between the axle housing and the drum backing plate with '71-'72 5 lug axles, OR have your axles redrilled to 5 lug pattern. I believe board venders sell bolt in 5 lug axles also. If you guys will help me here, I'll put this in the FAQ section. I looked and didn't see it. Any info anyone can add?
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com Last edited by HuggerCST; 11-09-2004 at 01:12 AM. |
Chevy Nuttttt
rear axle
the easyest thing to do for the rear is to get a rear out of anything from a 71-a 78 and just change spring mounts. I did it on my 67. the other thing to remember is to move the shock mounts. it only took abought 3 hours
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell ![]() ![]() |
Rear spacer width is 3/4" on each side 11/2' total
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
#5 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
#6 | |
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
MI '69
![]() Join Date: Oct 2004
resurecting this post....
any thoughts regarding what year joints to use when buying the front end conversion? im planning on purchasing some new a arms from ART but i need to know what kind of joints im going to use, and consequently, what year of brake conversion.... are there any pros or cons to using the 73+ or the old style? whats the deal here?
1967 Chevy (Project Frankenstein) 1973 K5 Blazer |
Got Light Emitting Diode?
what ever year you choose thats what year joints and tie rods you need. if you go past 81 and are looking for 6 lug rotors you need to make sure what you are getting, there is a heavy and light duty which has different thickness of rotor
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
MI '69
so basicly, the only things that have to match are my spindles which will come in the conversion kit, and the joints that will come on my new arms....
that makes things pretty easy, i was just concerned about differences on my steering connections.... if i go newer will my old steering stuff fit the same? or will i have to make changes there also? also, im probably going to go 5 lug... is that a good decision?
i perfer 6 just cause everyone is swaping to 5 but it all works the same. i am going to use all the 81 stuff so i dont have to worry about inner tie rods not fitting, but that does happen. there is an artical that goes off about it. i will see if i can find it
MI '69
yah, see if you can find that... i do'nt want to purchase a bunch of stuff and then have problems with it all.... my only concern with the lug stuff was finding rims i want.....
i already know which ones i want
MI '69
very nice.... that is one of the better paint schemes ive seen....
the rims are sweet also... any luck on finding that article?
heres some reading for ya
http://67-72chevytrucks.com/vboard/s...hlight=sleeves
#15 |
I am just curious... What is the big deal of 5lug vs. 6lug? The only reason I can see worth changing would be to run the classis Cragar SS wheels.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
#16 |
the reason alot of people change to 5 lug is for wheels. also there is no factory 1/2 ton 2wd 6 lug rotor, so when you change to front disc you either use stock rotors (5 lug) or buy aftermarket 6 lug rotors for 75 bucks a piece
#17 |
MI '69
thats good enough reason for me......
i plan to keep the truck for a while..... ok.... heres the final setup.... will it work..... "73-87 ball joints... proper tie rods included with package... compatible controll arms." stock power '69 steering....
#18 |
from what i have read yeah, havent completed the process yet. working on lowering it at the same time. got to collect those parts now
#19 |
MI '69
k, thanks for the help.....
oh, one more question.... im baggin the front with cool ride from ART. how low will the front go if i go with 2.5" drop spindles? i don't want the thing slammed but a lowered stance would be nice.
#20 |
i would like an answer to that too. i am (thinking about) making my own bag brackets and running a 2inch drop a arm.
#21 |
MI '69
where did you get those pictures you posted earlier?
#22 |
