11-09-2004, 08:06 PM | #1 |
Transfer case 208c2 or 241c??
I need help, don't know much about trasfer case models I have a model 208C2 with ratio 261 or a model 241C with ratio 272??? What is the differancein the two??????? Can anyone help???????
SEMPER FIDELIS |
11-09-2004, 09:06 PM | #2 |
I like cheese
I'm not possitive but I think the 241 has a better ratio with an OD trans. I've never had a 241 but thats what I hear.
Cruiser: 1972 K5, 400/TH350/NP205, D44 and 12Bolt, 35 TSLs. Trail rig: 86 K5, 350 TBI, SM465/NP205, 5.13s, 14ff locked, h1 beadlocks, 42" TSLs, 64" rears, 56" fronts, D60 locked, 35pline, drive flanges, crossover, hydro assist, OBA. Tow rig: 2002 F350 PSD CC Dually FX4, chipped, cold air intake, BFGs |
11-09-2004, 09:15 PM | #3 |
You should have the 241 in your truck, if it is the '89 Blazer you have up for sale.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 11-09-2004 at 09:20 PM. |
11-10-2004, 03:18 AM | #4 |
241C should be a drivers side drop IIRC, where the 208 is a passenger side. i think the passenger drop 241s are listed under a different model number.
11-10-2004, 07:55 AM | #5 |
Passenger drop 241s were used in '89 - '91 Blazers and Suburbans. The 241 is the newer design that replaced the 208 in '88 - '89. Both cases have similar specs. Supposedly the 241 has a better oiling system. Low range is also a bit deeper in the 241 as you have noted.
Tim |
11-16-2004, 03:00 PM | #6 |
Mental note one is not stronger than the other I have blow both models right to hellll. oil system is not worth talking about as both are fine. 241 is a little deeper but that is no matter with a 700 trans. lo range 1st gear is just silly especially with the 4.56 gear i have. I think I can go 2 mph, If i get a good downhill run. I now have a 208 installed.
11-16-2004, 05:52 PM | #7 |
why would you go for a 208 over a 241? the 241 not only offers the lower low range, but also the ability to upgrade to a SYE.
11-16-2004, 10:19 PM | #8 |
I think the NP241 has a higher tq input rating as well...but then again if its what you got, its what you got.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
