Lovin' Life in Miss.!
Progress Pics
I have been pretty bad about posting pics, and when I did there were more of my daughter than of the truck. Truck is in paint shop now and this is how she sits. If you spot something dirty or not blasted and painted..... Believe me, I know. Workin fast is the problem. This truck is my daily driver and I have been BORROWING a car while I do this. ....It's been almost 3 months.
Enjoy.
The truck... you hear that? No really, you did hear that?!!! |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
One more.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Look's pretty damn good ....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Left Foot Functioning
Lookin' good, CW...some questions.
Same serpentine setup as mine. Did you use the high-angle water neck from the donor? What app was that radiator hose from? Also, where'd you get the cover for the compressor? Thanks...SSOW ![]()
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
It looks great. I couldn't live with white fenderwells though, you're a brave soul......
Brian 72 C10 longbed 350/th400 Let the world change you and you will change the world. |
Still drivin' a Rat Rod
Looks good.Working on them and driving them is a hard thing to do.I am in the same situation.It sucks,but whatcha gonna do right
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
SSOW: Thanks, No. thermostat housing is stock application from napa. Upper hose is stock for 72 chevy truck from Kragens. Need to put an abrasion pad on it. It does rub the alternator. I bought the compressor from ebay. It does look kinda cool. Dunno for sure what the app is. I will check out the neighbors shop truck for you. Almost could swear he has the cover. 91 3/4 ton.
Peregrine: I've been gettin that a lot. I've owned a lot of white vehicles. I don't remember washing them nearly as much as the dark blue tahoe my wife has now. Anyway, if it does prove a pain in the a$$, it will be easy enough to drop em and re-spray em.
71 DELUX
When I saw it, it was in the garage, looks like it has "seen the light" so to speak. Might be able to come take peek this Saturday afternoon with my rugrat after soccer, I'll let you know. Great progress!
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
what serpentine setup did you use on this motor??? Is this from a late model???
Jeff, truck is in paint shop. Won't have it back for a couple of weeks. Sorry to say this, but looks like family weekend for me this time.
Dallas 71: My setup is from an early 90's 3/4 ton. Water pump is reverse rotation so keep that in mind. The brackets are cast aluminum.. They can be found in the GM Performance parts catalog for quite a penny. Drawback on em is I heard they tend to crack. Although, mine have not after a year on my truck and a decade or so on someone elses. Also, the passenger side bracket has a hole that is non-existent on pre-vortec heads. I match marked the center thinking to drill and tap it....but the center was quite a bit off the boss and I chickened out. Emailed GM performance parts and they were quite insistent that it was ok to run with only 2 bolts on that bracket... The jury is still out. There evidently is some steel serpentine brackets out there. I do not know year/model though. Saw em on a 55 a couple years back but was uninterested back then so questions were not asked. Hope this helps.
The truck... you hear that? No really, you did hear that?!!! Last edited by chickenwing; 10-02-2004 at 01:11 PM. |
Professional Grade
Take a look on an 89 Chev halfton, they've got an all steel serp bracket setup
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
I'm lovin it so far CW. Engine bay is clean and functional, cept for the garden hose colored heater hose. hehe
![]() I think the white wells look cool and will help brighten things up when working under the hood, changing spark plugs comes to mind, it's usually dark down in there behind headers and such. I gotta ask about the plug wires. Those are so clean and neat, out of the way. Mine are a big loose mess. Where would a guy order a setup like yours? Keep up the good work, Tug |
Yeah 89 I know have the steel brackets
#15 |
Tug: The garden hose is admittedly ugly. It is a silicone hose though and should last long long time. I spent a lot of time wiring this truck to hide as much of the harness as I could. All of the aux battery and fan control wiring was ran below the upper radiator support. The fuel pump and ignition relays are hid behind the aux batt. On the driver fender, I had to leave the fuse block out for access. I left the aux batt relay out for roadside trouble-shooting purposes. It powers 2 relays through a (cough) ford crash switch. Then there is a bump switch I put in. On the passenger fender are 2 maxi-fuses, 1 for main harness protection other for fans also 1 junction with fusible link for aux batt..
I will try to post some closer shots of my motor. I really like how the temp sending, choke and compressor wires came out. I ran em through high heat spark plug wire looms from napa and secured them to the valve covers with regular loom clips. The plug wire holders are pretty standard stuff. I did find some good lookin high heat boots to slip on the ends. The wires themselves are just some cheaper accel wires that I cut to fit. Buy em at Kragens. Guess you never made your own wires before. Pay attention to the instructions. There are some fancy smancy tools to make this easy. I found a cheap aluminum crimp die. It even has a razor slot so you dont nick the core when you strip off the insulation. The last neat thing was the starter harnness I got from Summit. It comes with a weatherpak connector so you can disconnect it for easy starter removal. Thanks for the props on the fender wells. I've ran across a lot of critics. If it doesn't work out I'll change the color. Stickshift: I checked out the 91 3/4 ton next door and it does not have the cover. Sorry, no leads. The picture has allready rolled off ebay and I do not remember the user name of who I bought it from. Anyone else ever saw a chrome R-4 compressor cover?
#16 |
Hey CW -
New question. I see you've run your heater hoses from the manifold to the core and then back to the radiator. I assume you've done this because the later reverse-rotation water pump has no outlet for the heater. I've got that problem, so what radiator application did you use? You've got it covered up well, but it looks like it may be a 4-core? None of the one's I've ordered so far have the heater outlets. Thanks....SSOW ![]()
#17 |
SSOW: Yes it is a 4 row. Pretty sure that was the original set-up. Anyway, It is a new stock aftermarket radiator since I drilled a nice 1/4" hole through the core fabbing up the fan mounts. You would think I had heard of a drill stop. The radiator shop I bought it from just brazed in the fitting. Sorry, don't want to remember the price!
#18 |
New Pics
Truck has been back from paint for a week solid now. Finally found time to put my grill surround, grill and bumper in. Sorry, it is Pheasant Season!!
#19 |
Chevy Nuttttt
for all who want them the compressor covers can be found in summit and jegs. also swweeettt long bed
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell ![]() ![]() |
