08-25-2004, 11:08 PM | #1 |
Junior Member
Window Regulator and Motor
I also am selling a front driver side power window motor and regulator from the same 1989 Suburban. Works great and will take $40.00 shipped if there is any interest. Wiring and plugs included uncut.
09-24-2004, 03:15 AM | #2 |
Junior Member
How about $35.00 Shipped? Anyone???
09-25-2004, 05:16 AM | #3 |
will it work in a 86 suburban?
09-25-2004, 05:18 AM | #4 |
my window doesn't roll up or down anymore i don't know if its the switch or the motor thingy. the back two work and sometimes the passenger front is stubborn
09-25-2004, 08:11 PM | #5 |
Junior Member
I will check my Hollander manual at work on Monday and will let you know. Pretty sure they interchange. I suppose it could be wiring but if you have a spare battery, you can take off your door panel and jump straight to the regulator with a couple pieces of wire. You'll know for sure that it is the regulator at that point. Cheaper than just buying the parts and guessing. Let me know what happens.
09-27-2004, 11:05 PM | #6 |
ok i'll check again monday after work. i am thinking i want the parts tho. but yeah i will check monday. i don't know how i am going to change the part tho. i got the panel and everything off....really tight in there . what do i jump? what happens if i get the polarity (using that correctly?) (pos/negative) wrong. i touched somthing bad and got some smoke
09-28-2004, 08:34 PM | #7 |
Junior Member
I don't know if you smoked either the motor or the wiring. Your problem might be more than the regulator now. You will have to do some testing with a current test light to see if your wiring is fried. Then you will also know which is pos-neg. Also check fuses. Give me a PM as soon as youv'e determined the problem. The Hollander manual says that my parts interchange with yours.
09-28-2004, 09:33 PM | #8 |
do you have any pics of the motor just want to make sure its the one that I need I have a 79 blazer but the doors are form a newer truck.
09-29-2004, 10:16 PM | #9 |
Junior Member
Here is the picture.
Hope this works. |
09-30-2004, 12:55 AM | #10 |
I will check tomorrow if its the same I will take it for 35 shipped
11-03-2004, 08:46 PM | #11 |
Hi I just installed the window motor today and it rolls up fine but when I try to roll the window down it rolls down for about 3 seconds and dies put mine back in and it works fine just a little slow that is the reason for me wanting a different motor your post said the motor worked great. Now im still in the same position less $35
11-06-2004, 10:57 PM | #12 |
bummer...poor guy least it wasn't an engine, eh?
11-20-2004, 11:58 PM | #13 |
Junior Member
Just checked this thread. Didn't tell me there was a problem with the motor. Read about it here first. He's being refunded including shipping. Ask him in about a week to a week and 1/2. I take the blame for a faulty motor. Worked the day before I shipped it. Things happen and I don't want a bad rep on this board.
