Old 06-28-2002, 04:17 AM   #1
Lippyp
English Chevy Owner
Lippyp's Avatar
Power Steering Pump Pictures
Can anyone post a picture of what the correct power steering pump setup including brackets looks like for a 1969 350 small block? Mine has been lashed together from something else and I need to know what it should look like before I can sort it out or source a replacement. Can I just change the correct brackets and pulley over to the pump already fitted? (see picture)
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 06-28-2002, 01:59 PM   #2
Rod
Here ya go.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 06-28-2002, 03:50 PM   #3
COBALT
COBALT's Avatar
I have the exact same problem. When a previous owner dropped in the '80 350 they used the accesories off the replacement vs. putting the originals back in.
The pump I have doesn't line up correctly, and is starting to fail.
Does anyone have pics of the pump inside the truck, with the lines to the steering box? That's really what we need...
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-28-2002, 04:29 PM   #4
bigvinnie
bigvinnie's Avatar
the pump and bracket that rod posted is correct, or at least it's the same as the one on my 350....as for the lines, my steering box has an inboard and an outboard fitting.... ouboard is return line, inboard (closest to frame) is pressure... pump has top and bottom fittings, top is return line and bottom is pressure line... hope this helps...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 06-28-2002, 07:35 PM   #5
Rod
This is the only other type pic I have saved so far.
Old 06-29-2002, 12:25 AM   #6
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
Hoo.. just tried to go snap you a couple pictures but I can't get a very good angle at the pump setup from the top. I would crawl underneath and shoot from there but it's storming like hell outside..
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 06-29-2002, 12:41 AM   #7
billogna
billogna's Avatar
I know mine is not all correct, but I did get the pump/ brackets from a short water pump truck. I had to shim between the pump bracket and block to make it line up. My pully is cast, not stamped, and the pump shaft is keyway type, not tapered pressfit type. I, too, would like a pic of an original ps equipped truck. Anyway, here is my pic.
'69 Chev Cust/10 swb, 350/700R4, 5"/6"
'70 Chev C10 swb, 67 front, 454/700r4, 4"/5"
'73 Chev stepper, 350/3 spd
'84 Chev K20 350/4 spd
'91 GMC 1500 Suburban 4x4, 350/700R4
billogna is offline   Reply With Quote
Old 06-29-2002, 09:24 AM   #8
Lippyp
English Chevy Owner
Lippyp's Avatar
Thanks for the pictures guys, really useful. I am going to a big American car show tomorrow at a place called Tatton Park just south of Manchester, about 1000 American vehicles expected to be there. Evereything from RV's to military vehicles with cars and trucks in between. I think mine is the only '67 truck thats gonna be there. There is a big autojumble so I may find a secondhand pump, stranger things have happened!
At least I know what I'm looking for now LOL!!
Phil
'67 C10 long fleet.
Old 06-29-2002, 11:20 AM   #9
Desert Rat
Desert Rat's Avatar
Billogna you can lose the shims if you get correct pulley,everything else looks right.Pulley you need last 3 numbers is 537
Desert Rat is offline   Reply With Quote
