Old 11-21-2004, 09:06 PM   #1
tim_and_bobbi_blazer
Tie Rod Question
My tie rod is appears to be bent pretty good. I'm wondering if any of you have ever had one like this. Is it bad enough to worry about? Can it be fixed? Does anyone know where I can get another one? Will later model trucks tie rods fit 1972 4x4 Blazers? Have attempted to add pictures but don't know if they went or not.
thank you
Bobbi
Last edited by tim_and_bobbi_blazer; 11-21-2004 at 09:09 PM. Reason: pictures didn't upload
tim_and_bobbi_blazer is offline   Reply With Quote
Old 11-21-2004, 09:12 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Tim, Mine Were All Replaced, If You Are Doing A Resto / Frame Off
I Would Just Consider Replacing It Now While Your In The Middle
Of It All, A Slight Bend Will Probably Not Be An Issue, But It Is A
Slight Possibility It Could Effect Your Front End Alignment.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-21-2004, 09:20 PM   #3
Thank you LUV2XCLR8
Yes, I'd like to replace it now. I added pictures to my Yahoo page. Can't get them to up load here. If you'd care to look at them, I pasted the link below. If you have a source for a new tie rod, please let me know.
Bobbi
http://pg.photos.yahoo.com/ph/tim_an...Zrc1BBRjwB5BOS
Old 11-21-2004, 10:57 PM   #4
Gee_Emm
Any parts store should have tie rod ends
Gee_Emm is offline   Reply With Quote
Old 11-21-2004, 11:13 PM   #5
MAC67
" SHOW ME"
MAC67's Avatar
get ready to shell out the bucks for those little golden tie rod ends ,
MAC67 is offline   Reply With Quote
Old 11-22-2004, 10:43 AM   #6
Thank you for responding
My tie rod ends are new. The part I'm looking for is the tie rod it's self.
Thank you
Bobbi
Old 11-22-2004, 02:34 PM   #7
jhow66
jhow66's Avatar
Tie rod
Take it off and have it straighten. Then have the toe in reset. (looks like it has been bumped).
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-22-2004, 06:39 PM   #8
ChevyDude
I just got done replaceing my tie rods inner/outer. It wasn't too bad on the wallet. I painted mine to match. The passenger side that is missing in the pic was drying at the time pic was taken
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 11-22-2004, 07:44 PM   #9
Thanks everybody
Just talked with my good friend Kenny up at Kennys (kennystrucks.com). He says the 73- are the same so I got options now. Thanks again to everyone who replied.
Bobbi
Old 11-22-2004, 08:19 PM   #10
jeffer
I'm suprised by the statement that the '73 up is the same. I found that not to be the case at all. For 67-72 4wd trucks, the tie rod ends are relatively short (5" or so) and the adjusting sleeve (tie rod) is very long (48" or so can't remember exactly.)
The '73 up has one short tie rod end (5" or so) one very long tie rod end (50" or so) w/ a hole in it for the steering stabilizer (not the u-bolt clamp like you have), and the adjusting sleeve (tie rod) is about 6" or so. I don't know if you could replace the whole setup (ends and adjusting sleeve) from a '73, but your ends would not work. I just went to Napa online to confirm my memory. Parts from the '73 are very different from a '72.
Mine was bent much worse than yours. I could not get the toe right and it ended up eating up the tires. I ended up buying a used one from a 67-72 4wd pickup (searched and searched for a new one, got the used one from Cheyenne Parts Northeast for like $50). Polished it up, coated it in POR-15 and it was good as new. You might also give these guys a look. www.rockstomper.com When I was looking, the only rod they offered required going to bigger ends and thus milling out the knuckle.
jeffer is offline   Reply With Quote
Old 11-22-2004, 08:23 PM   #11
Thanks for the reply Jeffer
Kenny might be asleep at the wheel. I'm still in the market for a stock one if I can find one.
Bobbi
Old 11-23-2004, 10:11 PM   #12
Jdog44
Jdog44's Avatar
I bent the hell out of my tie rod on a boulder will doing a river crossing. imagine my surprize when i coudnt buy one . If i remember right i bought one from a 76 blazer. But i think the taper on the tie rod ends where they bolt on where different .
72 k5 cst
Jdog44 is offline   Reply With Quote
