can it be done? what has to be done? thanks
2 WD truck?
http://community.webshots.com/user/hotrodhorn |
ya 2wd v-8
You can bolt a saginaw 4spd ,or M 20/21 muncie to the bell. Pilot hole size will be different. On the saginaw trans,you can use the front bearing retainer/throw out collar from a sag 3 spd. On the Muncie,you can have a ring made to press over the OD of the bearing retainer,or use a 67 or earlier bell for proper center hole size. You can also use the M22,& Borg T 10,but may have to change the clutch(spline count). You will need the drive shaft from a 3 spd stick,or a 350 T auto truck,& whatever you choose to use for a shifter. the bottom trans to bell bolts will go through from the inside, & have to have a nut..........69 longhorn
anytihng can be done, just depends on how bad you want to do it, IE how much headache you like to enjoy
try and get a 4 speed with 10 spline input to save a little bit of headache, most of the headache wil be from the driveshaft fab work unless you find a 3 speed manual(Sm318) or th350 67-72 truck with same engine as yours has in same location with same engine trees- for parts, dont trash that ch465 tranny though! damn good tranny ![]() good luck ------------------ Randy- Lincoln, IL r68c30@hotmail.com 71 C-10, trying to assemble....sigh.. parting out 5.0LTPI '81 cutlass supreme brougham *Paint is overrated © RSS Enterprises 2000 |
