![]() Join Date: Sep 2001
fuel pump flow direction backwards?
My new fuel pump has one side marked as IN, but it's the side pointing towards the radiator. does this seem backwards to anyone else? I've got a huge loop in the rubber line under the motor mount now... seems strange!
Nope. That's how my pump is. Inlet is pointing forward and maybe a few degrees outboard. Actually the fuel feed line should run along the inside of the framerail to within a few inches of the pump and a piece of hose should make a horseshoe bend into it.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() Last edited by Sweet72; 11-26-2004 at 08:59 PM. |
