#1 | |
its all about the +6 inches
On the road
![]() ![]() Join Date: Jan 2004
I just redid a set of 69-70 buckets that I got from Frank (Pickmup). From what I can tell the insert is shaped different and the foam is formed different between the 69-70 and 71-72. If you put them side by side and look at the seat back straight on, the upholstered insert tapers outward on the 69-70 from the top down, and it goes straight down on the 71-72. The bottoms do the same thing front to back. Those covers in the picture have the houndstooth insert and they are straight which makes me think 71-72. Maybe Frank or someone can post pictures of the different seats side by side so you can see the difference.
Mike
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com Last edited by GSFMECH; 11-27-2004 at 01:35 AM. Reason: Typo |
