Polyurethane or rubber bushings
Not sure which way to go on my suspension bushings. Any
one have any pros or cons on the subject? They are actually going on my 66 Impala but I'm sure someone has replaced them on your trucks?
70-Olds 442 66-Impala 4-dr. 67-K-10 87 Chev. 1/2 Ton 4x4 Swb |
Cantankerous Geezer
Poly costs more, is harder to install, but lasts far longer than rubber. Poly is the way to go.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
I agree, poly. It will make your steering more responsive as well.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
Installed poly on my suspension. The way to go. Wasn't that hard to install..
--------------------------------- 72 C10 SWB 350 Work in progress 98 HD Fatboy 09 HD Heritage Softail 05 Honda Element |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I installed poly on my 72 blazer and toyota .. Still looking good even though they do tend to squeak from time to time..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Life is a gamble
For those of you who have installed poly, what company did you use? Does it squeak much? And do any of you have graphite impregnanted polyurethane?
1970 Orange CST C-10 w/350, posi, Longbed The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine. -- Ralph Waldo Emerson |
Check with PST for your bushings. Evey now and then I may get a squeak but they will come with some stuff to prevent that. A little shot of silicone usually takes care of it if it does. The graphite impregnated bushings are the best and usually most expensive way to go.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
I've used Energy Suspension graphite-impregnated poly bushings. They work well to reduce squeaking, but only greaseable spring pins/shackles/A-arm bushings totally prevent squeaks (when bushings are kept lubed).
For a car's IFS, long-lived, slow-wearing poly maintains alignment settings best. Reduces tire wear from misalignment. Improves handling since the poly bushings wont deflect as much as rubber. Worn, over-deflecting rubber bushings allow tires to roll under in hard corners. Poly won't. Less tire roll=less tread shoulder wear. I could go on.... ![]() Edited for clarity! ![]() ![]()
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 11-28-2004 at 07:55 AM. |
Life is a gamble
So am I correct in understanding that Poly maintains alignment, so it reduces tire wear from misalignment, but creates tire roll in hard corners, which causes tread shoulder wear.
So your damned if you do, and damned if you don't. I don't know what to get now. What are you going to do bstack?
1970 Orange CST C-10 w/350, posi, Longbed The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine. -- Ralph Waldo Emerson Last edited by ACES; 11-28-2004 at 07:42 AM. |
#10 | |
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. Last edited by 4x4Poet; 11-28-2004 at 07:57 AM. |
Life is a gamble
Thanks 4x4Poet
I got it now. ![]()
Aces, still kind of up in the air on it. I've read some
articles on the net of some guys that has been in the business for a while and say that the older cars and trucks suspension were made to deflect with the rubber bushings and that using the new poly stuff puts a lot of strain on the other parts? Of course thats all they had back in the day to work with was the rubber. I guess I want the best of both worlds, a decent handling car and the original type ride. I'm redoing the whole suspension, springs shocks, the whole deal, so thats why I posted this question. Thanks for the replys
I'm going with rubber.I look at it this way,The rubber componets in the parts today just aren't the same as years ago.And,i'll probably be dead by the time any new parts i put on now have to be replaced!!
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
mikeoj, I tend to agree with ya on that one. I thought
the same thing!!
