Old 11-27-2004, 11:15 PM   #1
PTS Kustoms
Looking for frame rivet info
Hello!
A while back I beleive there was some information or someone had a supply of factory rivets for the 67-72 frames. Also has anyone installed these and how? Please let me know...
Thanks,
Perry
PTS
PTS Kustoms is offline   Reply With Quote
Old 11-28-2004, 04:40 PM   #2
meathead95
computer illiterate
meathead95's Avatar
mothertruckers is the man to contact for frame rivets
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-28-2004, 05:08 PM   #3
nu2-72
I just bought a bunch from Ed and he tells me the way to install them is with an air chisel tool. Cut the chisel end off. Have the round shaft machined to a cup shape, heat the ririts with a torch. Hold the head tight with a block or sledge head and impact away.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 11-28-2004, 05:51 PM   #4
68LSS1
68LSS1's Avatar
These guys got it covered. Back when I was doing old Mustangs I used a aircraft rivet set that I filed away the outer edge to open it up for the larger rivets. I then drilled a hole in a peice of 2" steel the size of the set shank. That gave me a tool for the head side. Then I used a 4X rivet gun with a flush set. Heated the rivet up like mentioned. Just don't over do the riveting as you'll crack the rivet on the tail side.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
