help with tilt column
I have a 78 k-10 with a tilt column, it has some dlop in it(dosen't lock tight) is there a way to adjust it without rebuilding the whole column?
72 c-10 81 c-30 67 c-10 just sittin in the woods) 70 C-10 " " " " to compleete frames 67, 70 - in woods 2002 toyota tundra. 12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker |
You just need to pull it apart and see if everything is in good order or worn out alot of times they just lossen up and you can retighted with a small anoumt of locktite. You do not have to replace everything just the bad parts
Professional Grade
No, unfortunately....
Just take your time, and get creative when you work on it and you'll be able to do it yourself. Be sure to remember how everything came apart. You'll need a torx socket (I juse used a 15 mm I think...) a puller for some pin things (I used a bar with a screw that threaded in and popped them out by prying against a thick screwdriver) a steering wheel puller, locktite, and a couple of screwdrivers / sockets. The objective is to take those torx bolts out, put some locktite on them, and thread them back on. So long as you watch how it all came apart, you can probally get it back together ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Insert Witty Text Here
http://www.chevyasylum.com/column/tiltcol.html
http://home.t-online.de/home/O_Scholz/steering.html Slonaker Last edited by Slonaker; 11-29-2004 at 11:34 AM. |
