What does this do?
I was working under the hood of the truck and was wondering what this is?
It has a blue, black and white wire coming from it. I have open ends on the blue and white wire and the black (maybe green) goes to the tranny. So.....what's it do?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
TCS system (Transmission/Temperature Controlled Spark). Allows vacuum timing advance only in high gear and when water temp is above 82 deg. F. That connector is attached to the system time delay relay. Your better off deleting this system or just bypass the vacuum solenoid so the distributor receives vacuum all the time.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() Last edited by Sweet72; 11-30-2004 at 09:47 PM. |
Its Magically Delicious
i yanked out my idle solenoid last weekend and hooked the dzzy to manifold vacuum .. i would love some pics on how to get rid of the other wiring and such thats involved with this system .. thanks
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
Posted by 71-longbed: i yanked out my idle solenoid last weekend
71-longbed, I hope you didn't yank the idle stop solenoid or you'll have a hell of a time getting her to idle and shut off when hot IF you still have the Q-jet in there. Okay, I know what you meant, TCS solenoid valve right? ![]()
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
huh ?? this is what i pulled
huh ???
I've always pulled those off and never had a problem...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
dont touch that wire Tim! that controls the lights in that "special" mine in your town! those with galucoma will be pi**ed at you!
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
thats alittle paranoid
For my Jimmy I had a manual tranny harness with that thingy on it. I just bought a repro auto tranny harness and the wire for that thingy isn't there. Why would GM put it there if we don't need it?
Lovin' Life in Miss.!
I thought that thing kicked on when the a/c was in operation. How's it work/what's it do. Hope I'm not strayin too far from the post.
The truck... you hear that? No really, you did hear that?!!! |
i just wanna know if I can take the damn thing off
#12 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#13 | |
Resident Curmudgeon
We have a ton of acid rain here from the Copper Smelter dumping crap all oevr town. It has eaten many paitn jobs. One of the main reasons I used industrial single stage enamel on the MUTT
![]() Good, if I don't need that thing on the firewall I'm takin it off. One wire goes to the tranny and the other 2 have open ends and aren't hooked to anything
#15 |
![]() Join Date: Mar 2000
That thing can come off. The solenoid in 71-longbeds post is an idle stop solenoid. It actually is for setting idle speed. It is hooked to ignition on power and the lever on the carb rests against it. You turn the plunger in and out to set your idle speed. It's great if you have an engine that tends to run on after shut down. When you turn the key off the solenoid de-energises and the carb butterflies shut completely so it can't diesel.
Saskatoon, Saskatchewan Canada |
#16 |
71 DELUX
StingRay...
Good bit of info there, thanks!
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
