Old 12-02-2004, 02:12 AM   #1
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
back brakes from a 76 fit?
The rearend went out of dads 72 yesterday,and so he pulled the 3rd member from a 76,and bolted the ring gear up,and bolted it right in.Even has the same spline axels,and ect.
The back brakes are an inch maybe an inch and a half wider than the ones on the 72 though.Would they also fit,using the backing plates from the 76,or would I have to use the axels too?If I have to use the axels they may be too long which would make the whole deal not worth it for no more gain than I would get .
How much of a difference would there actually be,would it be worth it at all?
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-02-2004, 02:35 AM   #2
junkyardjohn
junkyardjohn's Avatar
.. I PUT THE REAR BRAKE ASSY. INC. THE BACKING PLATE OFF OF A 75 TRUCK ON A 72 12 BOLT. IT WAS ABOUT 3/4 OR 1" WIDER SEEMS TO ME. IT'S A WORTH WILE UPDATE AS IT GIVES YOU A WHOLE LOT MORE SURFACE AREA ON THE REAR DRUMS. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 12-02-2004, 02:46 AM   #3
Brainchild
Brainchild's Avatar
Did you use the axels from the 75,or the 72 when you swapped it out?
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 12-02-2004, 10:59 AM   #4
72402
Thumbs up rear brakes
I believe the axles are the same length, the difference in the backing plates allows the use of the wider shoes.
72402 is offline   Reply With Quote
Old 12-02-2004, 12:01 PM   #5
junkyardjohn
BRAINCHILD .. THE ONLY THING I USED OFF THE 75 WAS THE BRAKE ASSY. FROM THE BACKING PLATES OUT TO & INCLUDING THE DRUMS. JOHN
junkyardjohn
DON'T RENT U-HAUL
