12-01-2004, 09:07 PM | #1 |
Life, Be In It.....
New rocker panels and front cab supports installed (pics)
Finally making some progress on the cab. The new NOS rockers and repro front cab supports are install. Drip rail shaved and replaced with 1/4 inch round bar. Gas filler neck closed up. The cab is now being blasted and primed.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
12-01-2004, 09:11 PM | #2 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
12-01-2004, 09:15 PM | #3 |
Life, Be In It.....
Here are a couple more pics. Once the cab in on the frame and the door rehung, the shaven drip rail will be completed.
12-01-2004, 09:27 PM | #4 |
That's awesome work!!
12-01-2004, 10:59 PM | #5 |
"Trucks with Class"
What are you blasting with? It looks like sand? That gives a great surface for primer to stick to and takes off all the old rust & filler.
12-01-2004, 11:14 PM | #6 |
Life, Be In It.....
I am not sure what the blast shop is using, it kind of a pink color. I know it is not sand.
12-01-2004, 11:33 PM | #7 |
cool,just got done with my bothers cab floor,all four cab supports,rockers,cab corners.A lot more work than everybody thinks
12-02-2004, 12:28 PM | #8 |
Finish the'71..or bust!
Looks GREAT!!! I wish mine were that far along. Good Work!
The blasting media might be Aluminum Oxide. I use it on my project and it works great. It is a darker 'maroon-ish/red' color out of the container...but once it gets blasted for one or two rounds it takes on a pinkish color as it breaks down. It costs quite a bit more than sand...but it gets the job done nice and quick...and I can usually get 3 to 4 cycles out of it before it becomes too fine to work well. Keep up the fantastic work! |
12-02-2004, 01:10 PM | #9 |
should just leave the rail shaved.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
12-02-2004, 01:42 PM | #10 |
man does that look familier!!did all mine some time ago and now is complete thank god! but yours is looking great as well keep up the good work!
gm's are #1 1967 chevrolet short step 1988 chev 4x4 1/2 ton 1989 gmc 1/2 ton 1991 chev 1/2 ton 4x4 1993 Jeep grand cherokee 4x4 And yes a 94 Ford Mustang. |
12-02-2004, 02:03 PM | #11 | |
