Rusty Rockerfeller
![]() Join Date: May 2003
more questions on this 350/454 swap
does anyone know if they made a 70 with a big block and a manual shift????i am having a time trying figure out clutch linkage.i moved the z-bar fram emount back including moving the little z bar ball back near the oil filter the but the rod doesnt work and this and that.I am about to snatch that 4 speed AND new clutch kit AND newly turned flywheel out and sell it and get me an automatic
More Cowbell....
Snatch it out....and sell the four-speed to me!!!!! (no, really, I would be interested if you go that route).
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
Rusty Rockerfeller
i may go that route but looks like the tranny is a saginaw not a muncie as i thought earlier.i may make someone a great deal
More Cowbell....
So. I don't mind that. I woud be replacing an existing Saginaw. Lemme' know if you decide to go that way.
Bigunde, do a post for rod from pedal to z-bar for three speed truck w/ v8, that should get you to piece that you need to complete your swap. The part should not be expensive. Someone correct me but is the trans. crossmember further forward for a I6 . This may be corrected with the shorter v8 rod, but you may have to move the bellhousing back- I don't think so, but you might
Rusty Rockerfeller
heya harold,you have been a great help,im just jinxed,hehe,anyways i got the rod from a v-8 but when i moved the z bar back to that other hole near the oil filter it wont even touch it.
Roadtrip!
![]() Join Date: Feb 2003
To answer your first question, I recently sold a 72 cheyenne, 1/2 ton, 2wd, 402 with a 3 speed column shift. ALL factory. So yes they were made and parts should be available somewhere... Hope this helps.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Truck addict
bigunde, you are having a bunch of problems with this swap. You are scaring me becuase I plan to tackle the exact same swap in a couple weeks. I guess it is going to be harder than I thought
1956 Chevy Napco 1972 Cheyenne Super 1970 K20 |
Rusty Rockerfeller
well too-much-stuff has given me a glimmer of hope if i can find all the linkage.
Truck addict
If you don't mind can you drop me a pm if you figure it out, and tell me how to do it. Thanks
Rusty Rockerfeller
you got it,my email is bigunde@bellsouth.net
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Seems to me that the manual trans big block trucks had a special trans crossmember as well. Someone will correct me if I am wrong!
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
![]() Join Date: Aug 2001
![]() JEREMY 5 .... THAT 70 TWO TONE, YELLOW & WHITE 3/4 TON IN YOUR AVATAR LOOKS LIKE A TRUCK THAT I USED TO OWN. DID IT COME FROM NEVADA?? ORIGIONALLY FROM COLORADO?? MOTOR OUT OF IT??. ![]() ![]() ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Let me check the build manual and see if I can find something that will help you get this sorted out Bigunde. I'll let you know shortly. Harold
#15 |
I can't find anything, I am going to the junk yard in the afternoon, I will check the location of the manual trans. cross member and get some reference points for you to go from. Harold
#16 |
Truck addict
junkyardjohn,
ya I got it from nevada. Didn't know it was orginally from Colorado though. I haven't looked but it would be extremely nice if the clutch linkage is still there.
