I miss this truck.
Vent!
So I've got a brand new battery and a Brand new Alternator, and it still died coming up the hill from the river this morning. Had to call a guy I work with and get him to come pick me up in his F#$D. If it hadn't been for the levee, I could have just let it roll back down the hill into the river and been done with it.
I know I'm not the first to have a battery drain issue, but it still makes you want to beat the last straight, unrusted piece of sheet metal into little pieces with a sledge hammer. I even happen to have a sledge hammer riding around in the back of the truck right now. Wouldn't I be so much less frustrated if I just beat the crap out of it, then rolled it off into the river???!!!!
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
If you still have the OE regulator & stuff, ditch it all for a one-wire Delco 10si. End of trouble. Brian
It sounds to me like you either got a bad alternator, you have a bad connection, or something is not hooked up correctly. Time for the multi-meter
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Did you replace the voltage regulator too or is it in your alternator?
I miss this truck.
Yeah, the voltage regulator is next to go. Probably should have done it before the Alt, but felt like the symptoms were leading me towards the alt. It doesn't help anything that every tool I own, and my Multi-meter are 2-1/2 hours away this week.
now thats a true COON DOG
![]() Join Date: Nov 2000
I also recentlly had the same problem with my burb, the battery was drining while I was driving with the headlights on.So I replaced the battery (it was weak anyway) and still the same problem, so asked my dad what he though. He told me to check the voltage regulator, went down to the local parts storesand walla problem solved for 15.00 bucks!
current project 67 ![]() 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) ![]() 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
You can have my old voltage regulator. I now have an internally regulated alternator.
I miss this truck.
Thanks Shawn, but I put one on last night, and at least that problem is solved. I still have more issues than a weekly magazine, but the battery drain is solved.
