Old 12-01-2004, 01:27 PM   #1
tkeduk8r
tkeduk8r's Avatar
what plug wires with headers???
I kinda stole the idea from the 67-72 board... but what kind of plug wires should i run with my new small block with summit headiers in my 74 2wd c10... I would like to run an 8mm ACDelco (i have a set i ordered for a 76 silverado since i have HEI) but I can return them on a set (76 vette maybe???) that may fit the headers better??? any suggestions???
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 12-01-2004, 08:27 PM   #2
76bonanza
76bonanza's Avatar
Get a custom set and cut them yourself the only way to go in my opinion. I like taylor products my self.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-02-2004, 12:34 AM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Either use Taylor Spiro-core or go for the big ones and use MSD wires. I am using both and am having good luck with them in the vehicles that I have put them on. Buy a good spark plug wire crimper and make the ends for the distributor yourself.
Old 12-03-2004, 04:43 PM   #4
PHOENIX
Custom make your own is the way to go.
I have always bought and used the Taylors.
I would recommend MSD or Taylor.
I just use a regular wire crimper and havent had one come loose yet.
EDIT:
BTW when I put my new exhuast on the wires are really close to the headers and the plug boots are almost touching in two spots. It really concerned me. I took a piece of scrap that I had from the Taylor set and put a MAPP gas torch to it. Let me tell you what, those suckers can take some heat. The looked pretty bad after a minute or so. I took the flame away and slapped the wire across the ground. The burnt flakes fell off and the inside wire was still protected I couldnt see it. I repeated this a few times in the same spot and they held up very well. I was very impressed with the heat these would take. I bought the boot protectors just to be safe.
Heres a couple pictures I had on here:
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 12-03-2004, 04:51 PM   #5
78chevstepside
78chevstepside's Avatar
I like the 90* angled boot plug wires for headers. Cut and fit your own work the best the best.
78chevstepside is offline   Reply With Quote
Old 12-03-2004, 04:55 PM   #6
PHOENIX
90 degree boots are the only ones that will fit with the headers I have.
I also had to buy the accell plugs to give a little more clearance in the two spots.
I have the Edelbrock 6527 headers, they are nice and all, but the pipes are really close to the plugs and makes it way more difficult to change the plugs.
I wish I could have found a set of hugger type headers with the air tubes. I might make some for next exhuast on the truck.
