You talkin to ME!
3spd to 4spd Swap
Would i have to change anything out or would it be a direct bolt in?
Also what would be involved in chaging from a 3 spd to a 6 spd? Any of you done this? Im considering buying a 68 with a 3spd thats been moved from the column to the floor and if i get it i want it changed to either a 4 or 5 spd or preferibly a 6 spd...it has a mildly built 350 so a 6 spd should make it ride great... Any help would be appreciated
Is this yours? PM If it is. 1998 Dodge Dakota Sport-Sold 1971 C10 Auto/307-Sold 1966 Mustang-sold 1976 GMC Short bed ![]() 1999 Ford Mustang 2002 Dodge Neon |
senior member
i put a 4 speed borg warner out of a chevelle and it was a direct bolt on the most expensive part was the shifter and the install kit
69 GMC bagged |
Still drivin' a Rat Rod
depends on what kind of 4 gear you're swapping out.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
senior member
if its out of a car it is a direct bolt on i should have said if its from a truck ull need to have a bigger hump
69 GMC bagged |
I bolted a Muncie M22(car-type)in my lil`Fleetside,no problem.Too go to an OD trans,you`ll probably need to do some mods.By the time cars were getting 5spds,the 3-on-the-tree was history.So,no direct swap.
