OBS guy
under dash oily; leaks oil in cab on trans hump
So, my truck has had this problem now for quite a while... I actually put it to the back of my mind, and then thought- hey maybe someone knows what's going on and can help me figure this out. It drips very slowly onto the trans hump and when I put my hand behind the dash, I get an oily mess.
I am 99.9% sure (speculation- haven't poked under there yet) that it is an oil pressure line for the oil pressure guage. Is that correct? I thought the oil pressure guage was a one wire sensor that went into the block... Now, my oil guage is definitely stock (or OEM looking anyways). My oil pressure guage works just fine. So a) is the leak an oil pressure line, or b) what else might it be?
88 Suburban Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear, Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more |
Stick head under dash. You will see copper line(oil pressure line). Tighten fitting on back of gauge. Remove head from under dash then try to work crick from neck. LOL
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
![]() Join Date: Feb 2001
Lmao................
OBS guy
Pretty funny... Thanks. You'll be here all week then?
![]() Join Date: May 2003
Oil
That"s probably what it is. Mine just let go this week but under the hood. Sprayed oil every ware. ( Mine was steel and rusted out )
Gary |
Rub oil on crick in neck...
Bob 68 C20 Camper Special |
its all about the +6 inches
You forgot step 3 - 5
#3 Wipe oil from haid and shoulders. #4 Cuss #5 clean truck floor. |
My other Love
hey at least the oil leaking on the floor is inhibiting rust! maybe back it off all the way and throw some teflon on it, wouldnt hurt if the threads were damaged or cross threaded
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
How many of us have taken out the guages for some reason, and forgot to put the oil line back in place, and started the truck ? ! ?
![]() ![]() Same sort of mess you are talking about!! Got Rags ! ? ![]() Darren
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
Cover your mouth.
OBS guy
Connection is nice and snug, so I will back it out and get some teflon tape in there.
Thanks again all! As always y'all have been there done that!
i had same problem... on both ends of the line. i got a kit from jegs for like 5 or 10 bucks. if the line is too far gone at either end you might have to replace like i did. it's easy except for getting to the block sending end of the line. meybe want to do it anyway... preventative maintenance?
RN U OVR |
dont use teflon tape it wont seal. you need to get a new fitting for the end of the line or just buy the 10 dollar copper line kit that comes with fittings. dont waste your time with teflon its a compression fitting and uses the metal line to seal not the threads
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
