Old 12-05-2004, 11:28 AM   #1
hotrodhomi
hotrodhomi's Avatar
door swap
Well, this weekend I bought a used hood from a guy with a 89 suburban to put on my '81 SWB. The burb was cherry I was shocked that he was parting it out. Anyway, He also had a great set of doors with power windows. First off, will these fit my truck? Second, is this any easy swap? What extra parts do I need off of the burb to make the windows work? Relays, wiring..ect.
hotrodhomi is offline   Reply With Quote
Old 12-05-2004, 11:39 AM   #2
smokinn
smokinn's Avatar
I dont think they will swap over. All parts from 81-87 will work except for maybe the fenders. 88-98 will swap over but I dont believe the doors will work on a 81. Someone correct me if im wrong.
Jason
smokinn is offline   Reply With Quote
Old 12-05-2004, 12:15 PM   #3
rolson1039
the doors will swap out i would get as much wiring as you can get and put it in like a factory setup
the doors from 73-87 or to 91 burb will bolt up but the inside trim ( door panels and attachments ) is different they will work tho trust me ive been rigging work trucks for years for crews to drive
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 12-05-2004, 08:11 PM   #4
hotrodhomi
hotrodhomi's Avatar
where are the relays? under the dash or under the hood?
Old 12-06-2004, 04:07 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
This is a fairly simple swap. Remove the wiring from the door jab (drill the rivets holding the boots) Unbolt the doors. Trace all wiring from the door jabs under the dash and disconnect them. Since it is on a burb, there will be 2 extra wires to get out. The power windows/locks will be on a secondary harness.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
