tire size?
if i put a taller tire on my truck will the speedometer read faster or slower than i am really moving?
It would read slower I think.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
slower
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
20' Daredevil (Ret)
![]() Join Date: May 2003
It'll read slower than your actual speed. Think of it this way - at a given rpm (and indicated speed), your tire will be rotating a certain number of times per mile travelled. Each tire rotation will push the truck forward a certain distance.
With a taller tire and at the same rpm, you will have the same number of tire rotations, but each rotation will push the truck a bit farther, since its circumference is greater. Since you will go farther in an equal amount of time, you are going faster than your indicated speed. I hope this makes sense. It was important to know back in the Sixties when I was putting taller tires on the musclecars - to keep the speeding tickets to a minimum! ![]()
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
you can buy a gear for your speedo to correct it. i've seen it somewhere.
