Old 12-05-2004, 04:39 PM   #1
ronsk10
column shifter arm removal
how do you remove the shifter arm. I just installed a megashifter and would like to remove the stock column arm. Thanks
ronsk10 is offline   Reply With Quote
Old 12-05-2004, 05:01 PM   #2
junkyardjohn
junkyardjohn's Avatar
THERE IS A PIN AT THE BASE OF THE SHIFTER ARE HOLDING THE ARM TO THE COLUMN. DRIVE THAT PIN OUT & THE SHIFTER ARM WILL PULL RIGHT OUT OF THE COLUMN. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
