12-04-2004, 09:43 AM | #1 |
New Member's First Post-Door Handle Help
Hello everyone-this is my first post although I have been cruising the board for a couple of weeks now. What a great place filled with knowledgeable people! I recently purchased a ’72 Cheyenne and am excited to work on it. I just replaced my brake master cylinder and now it seems like a booster is next-but I need some help on a simpler problem now. Most of my experience with older cars has been the work I’ve done on my ’68 volvo 1800s which is different ball of wax to say the least. I am trying to reattach a interior door handle to the Cheyenne and for the life of me can not figure out how to mount the clip on the handle so that it clips onto the spindle- I feel like a complete idiot! It's possible my spindle is the shorter version an from a older door but I don’t think so. Could someone please post a pic of how the clip goes on the handle befor it mounts on the spindle? It would be greatly appreciated. Thanks for the help!
12-04-2004, 10:02 AM | #2 |
Active Member
<sings> newbies, newbies helping newbies...
Just happened to have mine off and a camera handy: |
12-04-2004, 10:05 AM | #3 |
Yeah sometimes it seems silly the things we go to question, but then sometimse they just don't make sense till they are pointed out. Welcome to the board and a wealth of knowledge.
12-04-2004, 10:07 AM | #4 |
Active Member
By the way, the little clip is commonly referred to as an "Oh Jesus" clip, because of the tendancy of the owner to scream "OH JESUS!" as it shoots past their head when removing it.
12-04-2004, 10:09 AM | #5 | |
The LuvShack Garage
JESGORD - WELCOME 2 THE BOARD FROM WEST 10-UH-C
12-04-2004, 10:37 AM | #6 |
Thanks 7T2. I tried it that way and it didn't clip into place. Maybe it is a shorter door spindle thats my problem?
12-04-2004, 04:16 PM | #7 |
When you put it on you have to give it a pretty good push or tap it with a rubber mallet. The pieces of spring that are protuding into the hole where the shaft goes need to be pushed out by the end of the shaft so the handle will slide down and then the springs will snick into the grove about ½" down the shaft.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
12-04-2004, 05:43 PM | #8 |
Thanks Neonlarry -I'll get a mallet out and give 'er a good whack. I like to be carefull-maybe I've just been too gentle
12-04-2004, 06:33 PM | #9 |
OK, 3 things.......
7T2, while your picture is helpful.....The clip is on wrong. It goes in from the other side. Those little bumps (on the left in your pic) are there to keep it from sliding on too far. If it goes in too far the handle can fall off. The bends that fit into the grove move off-center to a narrower place on the shaft. Second, You shouldn't need a mallet. If the handle fits the splines properly with-out the clip being installed (check it first) then it only takes a little pressure to get it back on. The taper on the end of the shaft opens the clip, you might need to turn it a bit to align the splines. Third, it depends upon how you got it apart. (That is the question most people ask) If you stretched the clip, it may not fit right. I always heard the "Jesus clip" was because........once it flies across the room....only Jesus knows where it went. |
12-04-2004, 06:59 PM | #10 |
So longhair, from what you are saying, it sounds to me like it goes in front of the bumps on the left side of the pic not over them? Is that right?
12-04-2004, 07:06 PM | #11 | |
The LuvShack Garage
OTHER SIDE HAS TWO, BOTH WILL WORK, ONE WAY WILL BE TIGHTER.
12-04-2004, 07:10 PM | #12 | |
Active Member
While there IS a standoff on the other side as well (hard to see in the picture), mounting it that way would make it really difficult to get the clip off with a door handle removal tool. It should look like this: |
12-04-2004, 07:11 PM | #13 |
The LuvShack Garage
YUP
12-04-2004, 07:33 PM | #14 |
got it! Thanks guys
12-04-2004, 09:22 PM | #15 |
Welcome from SW Washington State...
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
12-05-2004, 11:34 AM | #16 |
Designated A-hole!
Welcome from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
12-05-2004, 05:34 PM | #17 |
PROJECT 7DEUCE
Welcome from southern oregon hope you got your door handle problem fixed...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-05-2004, 05:45 PM | #18 |
Thanks for all of the welcomes and the help. My clip was bent. Went to the parts store, got a new one and it snapped right on-no mallet needed.
12-05-2004, 07:14 PM | #19 |
Its Magically Delicious
Welcome from Oregon ... now that we've seen the door handle ... get some pics of your truck
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
